Paul Keinanen said:
On Thu, 21 Apr 2005 18:02:36 -0700, "Larry Brasfield"
The following '|>>|' quoted text is restored context
necessary to understand Paul's bare quotation.
|>>|>> > Only the dynamic power component is proportional to frequency.
|>>|>> True by definition and not at issue.
|>>|> No, not by definition. The dynamic power is also a second order
|>>|> function of the voltage, is that the definition of "dynamic power"?
|>>|Dynamic power is the power dissipated due to
|>>|charging capacitances. There was no voltage
|>>|change in the OP's question. Maybe that should
|>>|be assumed on his behalf.
|>>|> It *is* the issue, since the question was asked about (total) power,
|>>|> not a component of the power.
This is not a Trivial Pursuit game with a single correct answer or a
homework help desk for lazy students, this is a news group that
traditionally has been used for open ended discussions, in which
participants can learn from by actively taking part in the discussion
or by just following the discussion.
I agree with what you are saying but object to your
use of a quote lifted out of its context to imply that I
need such a tutorial. Without the context, you make
it appear that I attempted to constrain the discussion.
The (now restored) context shows otherwise.
As in engineering in general, there are usually not a single "correct"
answer, but it usually depends on many factors, which were not obvious
or stated in the original posting that stated a thread.
That lesson, too, is worthy but already well taken.
