I
Ian Stirling
In sci.chem.electrochem.battery John Woodgate said:I read in sci.electronics.design that DaveC <dave-
[email protected]> wrote (in <0001HW.BD2123CB000124FD09E9C0F0@ne
ws.individual.net>) about 'How do chargers determine what battery pack
is installed?', on Mon, 19 Jul 2004:
No. A theoretical current source develops an infinite voltage on no-
load. This is inconvenient, so practicable current sources have an
internal impedance Z in parallel with the current generator, so that the
no-load voltage Vo = IZ, I being the constant current. Vo is the
compliance voltage.
The current I can be achieved (approximately) only if Vo is very much
larger than the battery voltage.
With all modern semiconductor based power sources, the compliance
voltage is a few tenths of a volt below the maximum output voltage.
The number of powertools whose multi-battery constant current charger uses
a resistor, and a power supply of many times the voltage (apart from the very
cheapest untimed low power ones) can be probably counted on the fingers of
one ear.
