X-No-Archive: Yes
You forgot to factor in the fact pre-start almost never successfully starts on
first interruption.
So what? The glow starter keeps on heating the electrode more until
it reaches thermionic emission temperature and the arc strikes.
It very deliberately doesn't strike before then, as that causes
electrode coating sputtering.
Instant and rapid start lamps are rated from 12K to 24K
hours. Pre-start lamps are 6 to 7.5K.
This is completely meaningless. I had a computer room full of 8'
glow-starter lamps (probably around 200 tubes) which went over
100,000 hours, with probably only 25% failure rate. Trouble was
the phosphor was down to well under half light output and site
maintenance wouldn't replace tubes until they completely failed
to light, but I can assure you nothing about glow-starter limits
tube life to anywhere near as low as 7,500hrs.
The economic life of the phosphor is limited to perhaps 20-30k
hours. If you are switching once per day, the glow starter has
no effect on tube life. This assumes you have the correct rating
of glowstarter and it is of reasonable quality. Glowstart doesn't
work well with very short tubes on 240V (such as the older T5
tubes), because 240V can be enough to start them in cold cathode
mode without the electrodes being preheated, which quickly
sputters the coating off in the case of frequent switching.
In my garage, I have 3 identical 5' 65W fittings, except that I
have replaced the control gear in two of them with instant start
(the third is standard glow-start). They are all switched together
so ageing is identical, and they get switched quite frequently
because there are a number of things in the garage which are
frequently accessed. They've been there 3.5 years which isn't
long enough for any of the tubes to have failed, but the two
instant start ones are showing signs of electrode coating
sputtering, whereas the tube with glow start control gear still
looks brand new. My guess is the glow start will well outlast
the instant start tubes.
