How connect AC motor to mains?
Discussion in 'Sensors and Actuators' started by Curioushuman1, Nov 19, 2016.
  1. Curioushuman1
    Curioushuman1
    Nov 19, 2016
    How do I connect this three speed motor directly to the mains?
    [​IMG]
    [​IMG]
    The second image is the capacitor connected to the red and brown shown in the first image.
    There are 4 wires connected to the motor coloured white, yellow ,blue and black respectively. White wire has a high speed label. Yellow has a medium speed label and blue has a low speed label.
    I have no knowledge about motors. Hope someone can enlighten me on the
    (1)the type of motor that this is and
    (2)how to connect it directly to the electrical main
  2. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    It looks as if the capacitor is connected to the brown and red wires.
    The black wire is common (neutral) and one of the others is for the live feed.
    I do not know the type of motor but it is likely to be some kind of squirrel cage motor. The speed may be controlled by altering the leakage inductance and may need a load (fan?) to obtain the various speeds.
    Curioushuman1 likes this.
  3. Curioushuman1
    Curioushuman1
    Nov 19, 2016
    I tried connecting the black wire to neutral of mains and live of mains to the blue wire but it does not work but I saw a spark.
    It's a motor of a fan
  4. 73's de Edd
    73's de Edd
    3,068
    1,299
    Aug 21, 2015
    Sir Curioushuman . . . . . . .
    First is there any rotary drag of the motor shaft due to deteriorated lube problems.
    Your HOT AC line goes to black and stays there .
    The other AC line can be tried EXCLUSIVELY, only to blue or yellow or white.
    Try a SMART finger spinning on each speed at start up contacts IF the units does / did not start immediately on each of the prior trials.
    Prepare to temporarily sub in another 5-10 ufd paper/poly family capacitor of that voltage rating.
    That may be the exact reason that you now have that unit.
    A business next to me is a national repair center of ceiling fans from your country.
    With us sharing the same dumpster I see piles of your capacitors, fan bearings, end clipped wooden fan blades and pull switches in that dumpster.
    ( I sneak their control nuts from the switches)
    73's de Edd
