How can you tell if a system is oscillating?
Discussion in 'Electronic Design' started by Dr. David Kirkby, Sep 15, 2004.
  1. I have an electronic system consisting of 3 main parts, and whilst I
    don't think it is, there is a possibility the sytem is oscillating, as
    clearly a signal can be seen on an oscilloscope or spectrum analyser,
    with no input whatever.
    The system consists of:
    1) A special photodetector called an avalanche photodiode (APD), which
    detects light. The actual detector device has a gain of 30, and there
    are a couple of other stages of amplfifiction on the PCB.
    2) The output of this detector module is fed into an RF amplifer (500
    MHz bandwidth)
    3) The output of this amplifer is fed in to a band-pass filter, with a
    centre frequency of 70 MHz, and a bandwidth of +/- 15 MHz. (i.e. 3 dB
    points of 55 and 85 MHz).
    4) There are further stages of amplification, and variable
    attenuation. There are over 100 dB of RF amplification.
    If I look at the output of the system on an oscilloscope, there is a
    very noisy sine wave, with a period of about 15 ns (about 70 MHz). I
    don't have the unit in front of me, but assuming the peak-to-peak
    amplitude of the sine wave is 1 V, then there is about 300 mV p-pk of
    noise, so the sine wave looks very noisy indeed.
    If I look at the sytem on a spectrum analyser, I see a 'signal' that
    is some 30 MHz wide, centred on 70 MHz.
    There are two possibilities here.
    1) The detector device generates wide-band noise (which I know it
    does), which gets filtered, so no is narrow band. Then this is
    amplified, so the output consists of noise passed through a filter,
    which then takes on the shape of the filter.
    This is what I think is happening, but there is another possibility
    too.
    2) The system, with a very high gain (over 100 dB) is acting as an
    oscillator. Since the gain is much higher between 5 and 85 MHz due to
    the filter, it will osciallate somewhere between there, where the loop
    gain is > 1. Whether or not this would result in a clean oscillation,
    rather than something that is noisy on a spectrum analyser, I don't
    know. I suspect it would, which makes me think it is just the
    amplified noise I am seeing, and no osciallations.
    If I put into the optical detector a light source which is RF
    modulated, the output RF modulation can be seen on the spectrum
    analyser if the bandwidth scanned is small (20 kHz or less), but can't
    be seen on the oscilloscope at all. It is probably burried beneth the
    noise.
    But how can I determine for sure if the system is oscillating or not?
    I don't think it is, but the question arrises how does one prove this
    one way or the other?
    Dr. David Kirkby BSc MSc PhD CEng MIEE
  2. Ken Taylor
    Ken Taylor Guest
    How well shielded is the RF? 30MHz is around what I'd expect for a satellite
    transponder. Could you be picking up an external source? If you narrow down
    your spec an on this 30MHz can you see anything that looks like a signal of
    some sort?
    Ken
  3. Tim Wescott
    Tim Wescott Guest
    I wouldn't count on oscillation being clean, although it usually is.
    If it's oscillating there will be some critical gain where it will
    suddenly drop out of oscillation. If it's amplifying noise reducing the
    amplification will drop the output noise proportional to the decrease in
    gain.
    If you can reduce gain by removing stages or varying some component and
    see the effect suddenly pop into and out of existence then it's
    oscillating, otherwise it's noise.
  4. Chuck Olson
    Chuck Olson Guest
    Usually if it no longer obeys ohm's law, it's oscillating.
  5. You lost already. Gains of 40dB on one pcb are a limit.
    You have to seperate the stages with faraday boxes around.
    Such that the loop is not closed.
    Rene
  6. Mike Monett
    Mike Monett Guest
    (Dr. David Kirkby)
    wrote
    Sounds like you are looking at wideband noise with a center frequency
    of 70MHz. If the system were oscillating, there is nothing to limit
    the gain and you would see a square wave at the output instead of a
    sine wave. So the sine wave is a good sign:)
    When you add a small modulated signal and can see it on the spectrum
    analyzer, it means the amplifier is linear. If it were oscillating, it
    would be nonlinear and you would no longer be able to see this small
    signal in the output.
    I use a dental tool that has a short J-shaped piece of stainless steel
    with a sharp point mounted in a plastic holder. This has ~1pF stray
    capacity and acts as a small antenna. I use it to probe sensitive
    inputs to see if they break into oscillation when I touch them, or if
    a parasitic oscillation stops.
    With the large gain in your system, I would expect touching an input
    with a probe would cause the amplifier to break into oscillation, and
    you would see a square wave at the output. A small rf signal at the
    input would no longer be visible on a spectrum analyzer.
    So my conclusion is the amplifier is operating as it should, and you
    are to be congratulated on achieving such a high gain at these
    frequencies without oscillation. It would be a good idea to check the
    gain and phase vs frequency with a network analyzer to verify there is
    no unwanted peaking in the response. But you have to be very careful
    how you apply a signal to the input.
    Most single-shield coax cable starts leaking around -60 to -80dB, so
    the coax cables to the network analyzer can introduce unwanted
    coupling from the input to the output. You can check for this by
    grasping the cables at different points and see if the response
    changes. Try double-shielded coax if there is any coupling.
    Mike Monett
  7. Tim Shoppa
    Tim Shoppa Guest
    I think you're just seeing amplified noise, too. You've got so much
    gain that I'd be surprised if you weren't getting limiting in there too,
    and when the oscillator limits you're likely to see ringing at a much
    higher frequency (>>70 MHz).
    The "70 MHz wave" you see on your scope probably only extends a couple
    of cycles before disappearing into the noise, right? That's excactly
    what you'd expect from noise fed into a filter with a center of 70MHz
    and a Q of 4 or so.
    If you see pip(s) on the spectrum analyzer output, that could be
    oscillation. Complex active systems don't necessarily oscillate at
    only one mode, and especially when there's a lot of noise you'll be
    driven from one mode to another, but I'd expect if there were any relevant
    modes you'd see it as a pip on the noise bump. If the modes are so
    spread out and mushed around that they aren't pips, I'd contend that
    they are indistinguishable from noise so it doesn't matter. (Indeed,
    thermal noise is physically a whole bunch of nearly uncorrelated oscillators).
    Tim.
  8. Tim Shoppa
    Tim Shoppa Guest
    Wow, better not tell that to the guys who've been making IF strips
    with 80 dB of gain for the past half a century :)
    Tim.
  9. Rich Grise
    Rich Grise Guest
    I agree with Tim Wescott about the gain threshold - that's very easy to
    test, with a variable attenuator. Probe various parts of the circuit,
    to see what the signal looks like, because
    1. how noisy is the APD, and what's its output?
    2. 100 dB gain is a _lot_
    3. If there is some stray positive feedback, but not enough to oscillate,
    you'd have even more gain, so just before it oscillates it will be
    amplifying the system noise by as much as it can. But the spectrum
    you've described sounds just like well-filtered noise, albeit it
    does indicate some nonlinearity in the circuit, because it seems to
    be modulating, and not just adding, but that could be more an artifact
    of the filter's response.
    What happens if you replace the sensor with a short? (or if there's
    supposed to be an offset or bias current, you should simulate that,
    but as quietly as possible.)
    Good Luck!
    Rich
  10. The system is seeing 70 MHz, not 30, which is to be expected as the
    filter is centred there.
    The very front end device (a commerical unit) is not particulary well
    shileded it must be said - it will be when boxed up. All amplifers are
    well shielded, and for the most part, semi-rigid coax with a solid
    outer is used connecting the various stages together. Where that is
    not possible due to mechnanical reasons, good quality coax is used.
    I have never seen anything that looks like a signal, unless I either
    put the light into it, or wave a piece of coax nearby connecting to a
    tracking generator. Clearly with a local source of transmitter
    (tracking generator for the spectrum analyser), the device does detect
    this.
  11. Yes, that was my feeling too.
    Good point. I have reduced the gain by 32 dB with a PIN diode
    attenuator, and notice the output drop by the same amount, indicating
    it is linear.
    It all points to a stable system.
  12. These are not on one PCB.
    That is done. Each gain stage is a shielded enclosure, with good
    qualtiy coax (usually semi-rigid with a solid outer) connecting the
    stages.
  13. I read in sci.electronics.design that Tim Shoppa <[email protected]
    edge.com> wrote (in <>)
    about 'How can you tell if a system is oscillating?', on Wed, 15 Sep
    2004:
    Before WW2, 110 kHz IF amplifiers in well-designed BC receivers achieved
    approaching 80 dB, most of it in one stage!
  14. But for a square wave one needs harmonics. And the gain at the second
    harmonic (140 MHz) is << 100 dB, due to the attemiatom of the filter.
    Seeing a signal does not reall prove it is linear, but the output is
    proportional to the input, so I think that proves it is linear.
    But there is nowhere really for the signal to leak out back to the
    input, due to the use of good coax, and fully shielded boxes. So
    whilst touching the input will no doubt cause it to pick up radio
    signals, I would not expect it to osciallate, due to the shielding.
    I don't have a network analyser. Could perhaps borrow one, but don't
    have easy access to one.
    I tend to use semi-rigid, or double-shielded. I avoid cheap coax.
    Dr. David Kirkby
  15. Limiting is a problem, if I run with
    a) Little attenuation.
    b) The noisy front end.
    The final output stage is rated at +10 dBm (1 dB compression). I only
    need +4 dBm, but was getting a lot less power (around -20 dBm) at the
    fundamental frequency, when an RF modulated light source is put in to
    the detector module. The RF modulated light source produces a signal
    of around -90 dBm at the exact frequency of the modulation.
    With the -90 dBm at 70 MHz from the noisy detector, the system has a
    gain of only 70 dB, so produces -20 dBm. With the same -90 dBm from a
    clean signal generator, the gain is 100 dB, giving an output of +10
    dBm. So the noisy detector module is limiting the gain, there is no
    doubt.
    In fact, if I increase the increase the attenuation (reduce gain), the
    output will increase. This I am convinced is the output stages
    saturating. But if a signal generator is put into the system, it works
    exactly as expected, in a linear fashion.
    I think what is happening is that the power in the noise is
    significant over the bandwidth of the filter, so the final amplifer
    saturates - using a larger amplifer, rated at +20 dBm, gives more
    apparent gain and more output.
    I have a variable (0 to 31.5 dB) attenuator in the system. If the
    attenuation is set too low, harmonics are indeed seen, as the system
    saturates.
    I intend substituing a narrower (crystal, rather than LC) filter, to
    reduce the noise power, so the amplifer does not have to amplify all
    the unwanted rubbish. The noise power should be proportional to
    bandwidth.
    Not sure what you mean there?
    No, only harmonics are seen if overdriven.
    Thanks for your points.
    Everyone is convincing me the system is not oscillating, but I am just
    filtering noise.
  16. Fred Bartoli
    Fred Bartoli Guest
    "Dr. David Kirkby" <> a
    écrit dans le message de
    You should be able to calculate the expected output noise. Is it near that
    value ?
    Also, you mention possible saturation :
    I've built an IF amp, at a much lower freq though (100kHz), that have 145dB
    gain. With 2nV/root(Hz) input referred noise and about 7Mhz (uncut) BW this
    is 40µVpp and I "only" need 110dB to saturate the stages to +/-10V, leaving
    no room for the signal. You have 4 times that BW and you'll probably have to
    cut your BW, or gain to restore dynamique range.
    I was also prepared to write that at 70MHz, 50R, 100dB you only need 0.5fF
    (femtoF) to close the loop at unity gain. You seem to have done it right,
    but 0.5fF is pretty low.
  17. At what frequency ?
    I found broadband amplifiers to be tricky. If -80dB of the
    output leaks to the input you're there. At 0 to 500MHz,
    the phase condition is easily met at a frequency.
    Rene
  18. And the shielded enclosures are bolted to a solid aluminum ?
    Any reflections on the coax appear as shield currents and
    propagate from there.
    Rene
  19. Mike Monett
    Mike Monett Guest
    (Dr. David Kirkby) wrote
    Ah, so the bandpass filter is after the 500MHz amplifier. You
    described this clearly at the beginning.
    In this case, if there were coupling from the 500MHz amp to the
    input of the detector, the system could oscillate at any frequency
    where the phase shift was an exact multiple of 360 degrees and the
    loop gain was greater than unity.
    The oscillation would be highly unlikely to be centered on the 70MHz
    bandpass filter. In fact, it could be outside the filter bandpass
    and you would not see any signal at the output!
    If the system oscillated at some frequency within the bandpass of
    the filter, you would see a sine wave, but it would be free of noise
    since the output amplifier would be limiting.
    So the noisy sine wave centered on 70MHz is a clear indication the
    system is operating properly and not oscillating. Which is the
    conclusion you have already reached. But we need to explain the
    reason for the noisy sine wave.
    I searched for examples of narrowband gaussian noise, but had no
    luck. So I will try a hand-waving thought experiment.
    Suppose you take a perfect 1KHz sine wave and display it on a scope,
    which is triggered at the positive-going zero crossing. You are now
    viewing a standard sine wave. If you go 1 millisecond downstream,
    you see a second positive-going zero crossing with no jitter.
    Now a real signal is actually a collection of noise signals in a
    narrow bandwith. So lets open the bandwidth a little and see what
    happens.
    If we increase the bandwidth of the noise to 10Hz, you will start to
    see some fuzz in the second zero crossing. At a bandwidth of 100Hz,
    the entire sine wave will show considerable noise, nut not quite as
    bad as what you observed at 70MHz.
    However, if we increase the noise bandwidth of the signal to 428Hz,
    it should look very much like what you observe at 70MHz. (from your
    center frequency and bandwidth: (30/70)*1e3=428)
    The first zero crossing is a tight point due to the trigger
    threshold, but the signal at the second zero crossing is full of
    noise. The sine wave deteoriates rapidly beyond this due to the
    noise, and at some point is no longer recognizable.
    Does this help explain how the input noise in your system can look
    like a sine wave after the bandpass filter?
    Mike
