I am building a POE powered diagnostic tool which has a wifi access point in it. It works with a smartphone wifi app.
Everything is good except that when you unplug it from one POE switch to put it in another, the wifi will drop (obviously), but worse the phone will possibly acquire a new access point if another is available.
Then to keep using the device you have to disconnect and reconnect wifi which is a pain. But if I could just keep it on for a few seconds while I change cables everything would be fine.
I know it's possible using batteries or capacitors but the problem is that I have very little space in my case left.
So the requirements are
3w at 9v for 60 seconds with components that fit in a space of 38mm X 20mm X 10mm.
Price isn't a major concern.
