How can I connect this microphone and recorder to AA-batteries?
Discussion in 'General Electronics Discussion' started by Lene Larsen, Jan 17, 2019.
  1. Lene Larsen
    Lene Larsen
    28
    4
    Feb 1, 2018
    Can anyone tell me, where I connect the AA-batteries to this item? I cant find the right two "legs".
  2. (*steve*)
    25,170
    2,686
    Do you have a link to any documentation?
    Lene Larsen likes this.
  3. ChosunOne
    ChosunOne
    315
    72
    Jun 20, 2010
    It might help if we could see a clear picture of how the PCB is labeled. I can't really make out any of the labels from the pictures provided.
  4. Bluejets
    Bluejets
    3,423
    691
    Oct 5, 2014
    Vcc is positive of power supply in and Gnd is the negative.
    Looks like "record in" will be REC and GND.
    No idea what the rest does.
    Did they provide any data sheet?
    If not and the above info is not enough, you may have to Google or Youtube for anything else.
    If using AA batteries, I'd tend to use at least 3 in series to give 4.5v nominal.
    If you only use 2, the nominal voltage will be right on the lower limit of 3v for the device to work and as the battery voltage drops, operation will suffer.
    Edit....just checked Youtube and there are at least 8 or 10 videos there that should help.
    Did a Youtube search for "ISD1820 Voice Recording"
    Lene Larsen and davenn like this.
  5. davenn
    davenn Moderator
    13,207
    1,730
    the mic is on the PCB
    REC is more likely to be for a remote record on /off switch maybe ??? hahaha
    these clowns that sell this stuff without instruction should be strung out to dry
  6. Lene Larsen
    Lene Larsen
    28
    4
    Feb 1, 2018
  7. Bluejets
    Bluejets
    3,423
    691
    Oct 5, 2014
    Yes, I saw that after I posted.......... usual thing , foot in mouth...:rolleyes:
    davenn and Lene Larsen like this.
  8. davenn
    davenn Moderator
    13,207
    1,730
    it gets worse as one grows older I have discovered ;) ;)
    good stuff :)
