K
Ken G.
A DVD player made with vacum tubes .
David said:The size of Texas.
Just for reference...from the Web...Doc said:And about as dependable as an Italian sports car from the 60's.
Sam said:How do you want to implement it? Replace each transistor or diode with
a vacuum tube? Or redesign it to use vacuum tubes in an optimal way?
The optics/front-end stuff would be fairly simple, probably a few dozen
tubes. But the error correction, MPEG decoding, and video output could
eat up thousands of tubes, even excluding the multi-MB memory. You
could use core memory instead of SRAM or DRAM for that.
exray said:Just for reference...from the Web...
Re the ENIAC computer...which btw had no CD drive...
It was 10 feet tall, occupied 1,000 square feet of floor- space, weighed
in at approximately 30 tons, and used more than 70,000 resistors, 10,000
capacitors, 6,000 switches, and 18,000 vacuum tubes. The final machine
required 150 kilowatts of power, which was enough to light a small town.
One of the greatest problems with computers built from vacuum tubes was
reliability; 90% of ENIAC's down-time was attributed to locating and
replacing burnt-out tubes. Records from 1952 show that approximately
19,000 vacuum tubes had to be replaced in that year alone, which
averages out to about 50 tubes a day!
Ah, the good old days.
-Bill M
-Bill M
LASERandDVDfan said:The only thing that vaccum tubes might be a benefit is with the analogue audio
outputs.
Enormous, a several orders of magnitude bigger than the Eniac. And because
its size the circuits would probably not be fast enough to be able to
process the datastream from DVD discs at normal playback speed.
AC> said:Enormous, a several orders of magnitude bigger than the Eniac. And because
LASERandDVDfan said:Depends on what part of the player you would want to have vaccum tubes in the
player. Plus, you'd need a power supply designed to supply the necessary power
to drive electron tubes.
outputs. Of course, this benefit becomes pointless if you use the digital
outputs instead of the analogue outputs. Tubes may not be ideal for dealing
with video signal outputs. Also, implementing vaccum tubes for all the
computerized functions would be totally impractical.
Asimov said:"Andy Cuffe" bravely wrote to "All" (15 Apr 04 12:53:51)
--- on the heady topic of "Re: How big would a tube dvd player be"
AC> From: Andy Cuffe <[email protected]>
AC> Xref: aeinews sci.electronics.repair:25802
AC> On Thu, 15 Apr 2004 10:45:58 +0200, "Peter van Merkerk"
AC> The size problem is one thing that would be impossible to overcome.
AC> One of the main reasons modern computers are so much faster is because
AC> they are much smaller. The speed of electricity is a major factor in
AC> determining the speed of a computer. Even with discrete transistors
AC> capable of operating in the GHz range, the speed would be limited to
AC> maybe a few MHz by the length of the wires needed to connect
AC> everything.
AC> Andy Cuffe
AC> [email protected]
There is always pie in the sky stuff of which I can think of a couple
of examples. A really fast 1 bit tube computer could be used to
generate a virtual holographic photonic computer?
(i.e. TOS crew member in red uniform gets vaporized by laser beam!)
More down to earth is that tubes today can benefit from the same
modern microminiaturization technology as IC's. One huge benefit of
using the same lithographic methods is that cathodes can be built up
so sharp that they don't require a heat source to achieve electron
emission at the nanometer distances involved. Effectively a solid
state version of a tube. One can thus pack not that much less density
of tubes as with transistors. I think effectively it might be hard to
tell one from the other, both physically and performance wise!
If you look under the hood DVD's are mostly empty space as is...
So I must disagree and state that a DVD player using this type of
nanotechnology tubes could be just about the same size as IC types.
audio
Why?
