How an electromagnet can calculate kilogram
Status
Not open for further replies.
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
No idea what a Kibble balance is , we used to kibble grain for animals to eat.
The kilogram is a unit of mass, not weight so gravity does not enter into it.
Ylli
Jun 19, 2018
405
Jun 19, 2018
405
The BBC article implies that the force exerted by the 1 kg mass is balanced against the force generated by the electromagnet. But the force exerted by the 1 kg mass is dependent on the gravitational field which it is in.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
A Kiligram is a kilogram in any gravity field (whereas a pound is not).
Kg is a measure of mass, lb is a measure of weight.
The force could be exerted perpendicularly to the gravitational field.
HarryA
Jan 22, 2017
81
Jan 22, 2017
81
"In this new application, the balance will be used in the opposite sense; the current in the coils necessary
to support the weight of a standard kilogram mass will be measured, "weighing" the kilogram.
The weight of the kilogram is then used to compute the mass of the kilogram by accurately
determining the local gravitational acceleration."
Now one has to determining the local gravitational acceleration.
You will need an apple? ;)
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
According to Wikipedia the pound is a measure of mass which equal 0.453 592 37kg
I got all tied up in school with trouble understanding the poundal:)
FuZZ1L0G1C
Mar 25, 2014
366
Mar 25, 2014
366
Mass is density per displaced volume, or "lb/ft.sq \ kg/m.sq", and has inertia.
Weight is the gravitational attractive force between two masses.
A mass of "x" would weigh eg 67 kg on terra firma, but only ±23 kg on the lunar surface, and weigh much more on Neptune.
Gravitational force on Earth varies slightly depending on altitude, but the Wiki article mentions that g is measured as part of the calculation process.
I always thought Kilogram and Pound were both masses (or "weight" on a planet), - just a conversion of one unit to another.
Status
