D
Dave VanHorn
I'm investigating some field failures.
Unfortunately, the connector manufacturers are gone for the weekend, of
course.
There's a failure happening in a board stacking header, using these two
parts:
Samtec P/N:MMS-112-02-T-DV-LC-K-TR (female, gold)
Samtec P/N:ASP-106552-02 (Custom Dim. based
on the TW Series) Longer pin version of a TW-12-12-T-D-800-090
Male pins, tin.
The board stacking connectors are Samtec pins and sockets, used to stack two
PCBs together.
There is a power connector on the A board, being connected to the B board
through the stacking header.
The power supply is 9-16V at 2.25A from a wall-wart or car lighter plug.
Both sides of this travel through the stacking connector on adjacent pins,
to the B board, where they meet a diode bridge, and go into a switching
supply.
Only these pins in the connector are failing.
When they fail, they go high resistance, so that on the B board, the power
supply measures 2-5V with 15V on the input. No observable heating in this
failure mode.
If the board stack is disturbed, then the connectors "heal" and will work
for some time, minutes or days.
The connector ratings are not defined in terms of a hard limit, rather a
temperature rise over ambient. I know that we have failures where the
ambient did not exceed 40C.
The connectors are shown to have temperature rises by the mfgr's docs:
3A is a 27C rise, in gold, 14 in tin, 2A is 11C in gold and 7 in tin.
We are using the gold version (side note, I'm wondering why the gold is
worse!)
In the end, I would expect something like say 20C rise over 40C ambient,
sitting us at 60C,
Operating temp range is spec'd as -65C to +125C
With the current that I know is flowing here, I just don't see a reason for
failure.
Before I go off looking for ways to get wild current, does anyone see why
these connectors shouldn't handle appx 2A 24/7/365 under these conditions?
course.
parts:
Male pins, tin.
PCBs together.
supply.
failure mode.
worse!)
sitting us at 60C,
failure.
