household electrical question
Discussion in 'Electrical Engineering' started by James O'Donnell, Aug 7, 2003.
  1. Anyone seen a type of switch for 240V circuit which is a clockwork (not
    digital) timer?
    You simply wind the pointer round to the desired number of minutes (up
    to 60 mins or so) and it keeps the circuit closed for that amount of
    time e.g. for extractor fan in bathroom.
    I last saw one of these in the USA 7 years ago but can't find them in
    the UK.
    Jim
  2. Tom Grqyson
    Tom Grqyson Guest
    | digital) timer?
    | the UK.
    | Jim
    In Australia we have some timeswitches that sound like what you want.
    There may be an equivilant in the US.
    It is used for stairwell illumination. They normally have one at each door
    and you press the big button in all the way. It has some sort of pnumatic
    mechinism that only lets it come out slowly, As long as it is in, THe
    circuit is made, and the last little bit out toggles the overcenter switch.
    You adjust the time by adjusting the air bleed screw. After that the time is
    almost always the same for every operation.
    I Stuck one in a plastic box with a with a lead in and a lead out and used
    them for the kids when they used to read a book at night time in bed.
    I was able to get the time extended to about 30 minutes with a little
    fiddling.
    Tom Grayson
    press the button and read. If it goes out
  3. Rowbotth
    Rowbotth Guest
    I have two of them purchased in North America within the past 2 years.
    Manufacturer is "Intermatic". You might do a web search for the
    manufacturer and see if they are available in the UK?
    (Convenient little devils, aren't they?)
    HR.
  4. Thanks everyone. Surprising there's only one manufacturer of the
    household version of such things. Maybe I should corner the supply
    market for the UK! Household electricians haven't even heard of them.
    Jim
    James O'Donnell
    School of Engineering and Electronics
    The University of Edinburgh, King's Buildings, Mayfield Rd, Edinburgh
    EH9 3JL
    (Int +44) 131 650 5596, (Int +44) 131 650 6554 (FAX)
    Jim.O'
  5. Eric Palmer
    Eric Palmer Guest
    Most the ones I have used are pnewmatic not clockwork push button on outside
    setting screw on inside.
    Eric
  6. I have one connected to my whole house fan - it is clockwork - you can hear
    it ticking away in the wall
