Hotsprings Jetsetter Power PCB identification
Discussion in 'Power Electronics' started by Bigniv, Jan 26, 2020.
  1. Bigniv
    Bigniv
    5
    Jan 26, 2020
    I’m having problems identifying the power board (attached picture) for a Hotsprings Jetsetter hot tub 2009 make. I have had 2 failures of boards and I think it is a common fault on the power pcb... which I would like to replace to see if this fixes it. Any help would be appreciated?
  2. davenn
    davenn Moderator
    13,438
    1,807
    hi and welcome :)
    The photo is a bit small to see much detail... try again with one that is around 800x600 pixels
    With the little I could make out that that seems to be a power in/out board, are there other boards in the unit ?
    bertus likes this.
  3. Bigniv
    Bigniv
    5
    Jan 26, 2020
  4. Bigniv
    Bigniv
    5
    Jan 26, 2020
    I hope this photo helps better...
  5. davenn
    davenn Moderator
    13,438
    1,807
    OK thanks ... I don't see any obvious problems in that part of the board it's basically just a few connectors and PC tracks
    there's no burnt tracks etc
    how about a photo on the board that is off the top edge of the photo
  6. davenn
    davenn Moderator
    13,438
    1,807
    so what is the actual failure ? that is, what are the symptoms ?
  7. Bigniv
    Bigniv
    5
    Jan 26, 2020
    The light was flashing on my display on the hot tub and if I switched it off and back on it would reset and start working for a period and then start flashing again. Eventually it just went with a bang and I lost all power. Hence why I thought it was the power pcb.
  8. davenn
    davenn Moderator
    13,438
    1,807
    OK
    thanks for the pic … a bit dark but I cant see an y obvious burnt parts, maybe you can in better light on one side of the board or the other
    The PSU section is in the top left hand corner. chances are moisture/condensation has got into it at some stage and that has caused the failure
    look for corrosion on the board, if there is some, it may lead you to where the failure is
  9. Bluejets
    Bluejets
    3,690
    761
    Oct 5, 2014
    Should be signs of that somewhere I'd imagine.(black soot, burnt component, blown pcb track)
    Did the "bang" come from the board area or other location..??
    davenn likes this.
  10. Bigniv
    Bigniv
    5
    Jan 26, 2020
    I’m remembering it coming from the board area and when I checked the digital display it was blank, although there was power going to the board there was no power on the control side of the power...
