Hot plate for SMD rework
Discussion in 'Electronic Equipment' started by Russ, Apr 15, 2005.
  1. Russ
    Russ Guest
    I was at a friends place that makes hot plates and big ovens for SMD work.
    We took a piece of aluminum that was a little larger the the chip I wanted
    to remove. Then then put flux all over the chip and put the bottom of the
    board over the metal aluminum square and put it on the hot place. Heated to
    200 and the chip just slid off. Very clean no pulled up pads no scorching
    on the underside of the board. What am I missing here. It seems to work.
    Is there a drawback to removing and applying chips with this method? I
    didn't try remounting chips but that is next. No hot air or or pre heating.
    You can mount a stero microscope above it and not be in the way of the hot
    air gun. Anyone do this like this?
