S
Sam Goldwasser
Well, it finally happened. My wonderful, trusty, pampered 5FG finally
went belly up. It appeared to be at the point where Windows switches
to the normal resolution at boot time. There was no warning - the green
light just went off. I found the 2SC3998 shorted CBE. There is something
interesting though. Across C-E is a single LARGE damper diode in a TOP3
case but in addition, there are a pair of smaller diodes across this. Why?
They are in the same direction so it seems they should never conduct at all.
Backup? And, I did find cracked solder joints on these auxiliary diodes so
they connections might be suspect but how could this make any difference?
The monitor powers up fine without the HOT installed but I wonder what else
it might have damaged.
Is the underlying cause (assuming it's not those mystery diodes) related
to the likely bad pile of electrolytic caps or something else? The only
detectable indication of bad electrolytics was an occasional tendencey to
be slightly stretched vertically at power-on which would correct itself over
the period of a minute or so, usually it seemed, when it was very humid.
P.S. Is there any chance a 2SC3995 would sub (at least as a test) for
a 2SC3998 since I have one of those.
Thanks.
--- sam
Thanks.
--- sam
