Horizontal Bar
Discussion in 'Electronic Repair' started by Eagle0877, Feb 13, 2007.
  1. Eagle0877
    Eagle0877 Guest
    My RCA TV (which is quite old) recently started to act up. When you
    first power it on everything is fine, but after a short time the
    screen shrinks to a single horizontal bar at the center of the screen.
    This will not go away even if you turn the power of and then back on
    unless you leave it off for hours at a time.
    I would really like to be able to fix this if anyone has any ideas.
  2. JANA
    JANA Guest
    There are components, especially electrolytic capacitors in the vertical
    circuit area that have become thermo sensitive. I usually find these using
    freeze spray and a heat gun. After locating the ones that react to
    temperature shift, I replace them. If any parts fail permanently, then more
    complex troubleshooting will be require to service the set.
    JANA
    _____
  3. Guest
    Please give us a chasis # (usually starts with CTC then a number),
    that way you
    may get intelligent help. Since you said you had an OLD RCA TV try
    replacing the 6CG7
    vertical oscillator tube.
  4. me
    me Guest
