A
Andy
I am going to do some work in my car. So everything I talk about
should be ~12 volts. I have some electronics knowledge, but I am no
expert. I plan to use a relay to switch certain things. Here is how I
plan to hook up the relay (coil side):
Battery positive to toggle switch
Toggle switch to relay coil
Relay coil to ground
Ground to battery negative (Of course)
This will not be a short, will it? (Or do I need some sort of resistor
in there?) The relays I plan to use can be seen at
http://www.allelectronics.com/cgi-bin/category.cgi?category=search&item=RLY-412&type=store
The important detail (I think) of the relay is that the coil is 72
ohm.
Also, is it safe to use DIP switches? I don't know if they can handle
the current that will go through the relay coil.
ohm.
