Hooking up PIP TV
Discussion in 'Electronic Repair' started by [email protected], Sep 30, 2003.
  1. Guest
    I have (inherited) a Panasonic Projection TV 53" Model PT-51G42V.
    I have a Cablevison IO box and a VCR, which I will use for PIP.
    I've had lots of suggestions ..one from the Cablevision company
    .....and so far nothing worked. Can someone send a schematic of how to
    hook the PIP up???
    Thanx,
    Dom
  2. Bill Jr
    Bill Jr Guest
    Try http://www.pasc.panasonic.com/ and in the left column click on "parts
    and accessories"
    Input your model number and order the owners manual.
    It will have all the details and pictures for hooking up the set.
    Good Luck,
    Bill Jr
  3. Patch
    Patch Guest
    If you're using a cablevision IO box I don't see a way to do it. If the box
    works like the ones in my area, you can only receive one channel at a time.
    With your hook up can you watch one channel on the TV & record a different
    channel on the VCR? If the answer is no, then I don't see how it can be
    done. For P&P you need two separate signal sources. You might have to put up
    an external antenna, or a cable box with dual tuner outputs. (if there is
    such a thing)
  4. Gary Tait
    Gary Tait Guest
    Whereas On 29 Sep 2003 16:54:00 -0700, scribbled:
    , I thus relpy:
    Split the cable, hook one to the TV tuner, the other to the cable box
    in. Connect the cable box A/V out to the aux inputs on the TV.
