Hooking up a car audio amp
Discussion in 'Electronic Repair' started by Vey, May 24, 2007.
  1. Vey
    Vey Guest
    I have this old car amp that I don't know much about.
    It is a Motorola PA-4000.
    I want to hook it up and see if it will work without frying it.
    There are two groups of wire, One group is Red, Blue & Black.
    The other group is Long Black with an inline fuse, Medium length Black,
    Two short Blacks, short Orange and a short Yellow.
    On the side, there is a sticker that says "Speaker connections, Left
    Channel Yellow Black, Right Channel Orange Black. See Owners Manual."
    Typically, I would hook the red to + and the black from the first group
    to Black, but what about the blue wire?
    And why is the fuse on what looks like a ground wire?
  2. James Sweet
    James Sweet Guest
    The blue wire is remote power on, so the amp can be switched on by a low
    current source, usually the power antenna or amp lead of the head unit. Not
    sure why there's a fuse in that other bunch, if you open up the amp you may
    be able to identify where it goes.
  3. Arfa Daily
    Arfa Daily Guest
    Hey James - did you manage to find out from your uncle about the traffic
    light cable loops ?
    Agree with you on the blue wire being remote power on. He can just hook it
    to supply '+' to test the amp comes on.
    Arfa
  4. It's probably already fried, otherwise wouldn't it be being used?
  5. James Sweet
    James Sweet Guest
    I've got a number of old car amps people have given me. They get upgraded
    regularly by enthusiasts, ripped out of cars that were being sold or got
    wrecked, or pulled out of cars that came with systems installed which the
    new owner doesn't want. Just because it's out doesn't mean it's bad.
