Homemade LED ceiling light.
Discussion in 'Electronic Repair' started by [email protected], Jan 28, 2008.
  1. Guest
    I was thinking about bulding at least one.I think I would drill a lot of
    holes in a cheap wide shallow plastic bowl and put LED bulbs in the
    holes and connect to wires to a battery holder which would lay inside of
    the bowl and have three strings so as to hang the light evenly (sort of
    like those hanging potted plants) from my living room ceiling light, the
    little brass threaded ferule which holds the glass clobe on to the
    original ceiling light, I can make a little wire hook to hang the light
    from.This would be for if the electric power gets knocked out (stormy
    weather, whatever) for an extended lenght of time.I was wondering how
    well something like that might work out? If it works ok, I can build
    more LED battery powered ''ceiling lights'' for other rooms in my house.
    cuhulin
  2. Arfa Daily
    Arfa Daily Guest
    Why not make use of the stick-on battery powered LED lights that are made
    specifically for such things as power outages ? They are dirt cheap here in
    the UK, and seem to work quite well. I'm sure you could find something like
    a plastic plate to stick it to, in order to make your 'hanging basket'
    arrangement ??
    Arfa
  3. mike
    mike Guest
    If you want a project to fill some empty time, that's as good as any.
    Do the math and make sure you understand how little light you'll be
    getting.
    If you just want a light that works in an emergency, go buy one of the
    small fluorescent under-counter lights. Or a flashlight If you wait
    for summer, there's one at every other garage
    sale for a buck or less.
    If you have lots of extra cash to burn, buy a led flashlight. They make
    'em with as many zillion lights as you want. And they're cheaper than
    buying leds in low quantity.
    ledshoppe.com
    dealextreme.com
    If your power goes out a lot, put rechargeables. Use Eneloop or some
    other vendor's hybrid NiMH so there'll be some chance it will still have
    some charge when you need it.
    So, for wasting time and using up extra cash, a homemade led light
    works fine. And you can point to it and say, "hey, look what I can do."
    If you want light, give it up and buy one.
    mike
  4. Seconded. I bought a pack of three stick-on lights, each with five white
    LEDs, for less than $13 total (batteries included) at Costco.
  5. bz
    bz Guest
    wrote in 3253.bay.webtv.net:
    Solar Powered flash-light using LEDs.
    bogolight (buy one give one--to someone who needs light)
    http://www.bogolight.com/
    [I have no connection with the project except I just bought one/gave one).
    bz
    please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
    infinite set.
    remove ch100-5 to avoid spam trap
  6. Guest
    I have three little LED flashlights, one of them also has a little
    skinny flourascent light (not much thicker than a coathanger wire)
    running along the side of the flashlight.I also own six battery powered
    flourascent camp type lanterns, one of them is a Sears rechargable that
    I bought at the Goodwill store, but I don't have the adapter for the
    light.
    I have several small inverters and a lot of Everyready AAA and AA and C
    cell and D cell rechargable batteries with two Eveready rechargers.If I
    plugged one of the battery rechargers into one of my inverters, (12 volt
    D C to 120 volt AC) and connect the inverter to the battery in my van,
    wouldn't that charge the batteries up ok?
    cuhulin
  7. jakdedert
    jakdedert Guest
    I found 'em at an 'everything's a dollar' store for...well, you know.
    Found some at wally-world being closed out; four for
    $3.something...including batteries.
    The other day, I found an LED spotlight being closed out at Walgreen's
    for $3. It had a solar cell, three white LEDs, a charging circuit and
    two AA NiMHs.
    Alas, there was only one....
    jak
  8. default
    default Guest
    The "Dollar General" had some led flashlights for $4 sans batteries.
    14 LEDs and 3 AAA batteries. It's the first light I reach for.
    I agree, ledshoppe and dealextreme, both good sources for LEDs and
    flash lights. You may get a dud when buying hundreds of leds but that
    is rare. In 300 leds I had 4 bad ones from ledshoppe.
    http://www.dealextreme.com/details.dx/sku.3874 Ready made light for
    what the poster contemplates with 100+ degree beam spread.
  9. GregS
    GregS Guest
    It seems like a lot of work. I was going to install a bunch of LED ceiling pot lights,
    mostly in the kitchen. I was going to use X10 to control them. I found out X10 is
    not supposed to work with wall supplies and the light from normal LED's is too blue.
    Warm LED's are available now, so any light I install will have to be the warm type.
    They are also essential for art display lighting. The LED's I bought are 3 watt Luxeon
    for about $6 ea.
    The LED lanterns and flashlight are so cheap, that you should reconsider.
    I d think its very nice to have a house emergency supply of ceiling and floor
    runners, as a backup, and you can even use them all the time as added
    convenience and styling using different colors.
    greg
  10. Tim
    Tim Guest
    Check out this site I saw in another NG.
    http://www.emanator.demon.co.uk/bigclive/joule.htm
    It has a simple design to get the most out of the batteries. Lot's of
    other cool stuff on his site too. Just move up to the bigclive folder.
    - Tim -
  11. default
    default Guest
    That's a good schematic for a tiny voltage booster. I dates back to
    vacuum toobs and is called a "blocking oscillator." One application
    was the vertical oscillator in TV sets, another was audio code
    practice oscillator using a tapped audio output transformer.
    This guy is talking about a large number of LEDs so it is interesting
    that you present that method. I use it as a boost converter for 3V
    circuits as a bias supply for turning on mosfets - open circuit they
    can put out upwards of 80 Volts with no load - so with some attention
    to raising the power a little it might work a large string of LEDs
    from a single 1.5 V cell.
    No load, and it may destroy the transistor with the HV spike.
