Home Theater Systems and Cable Dressing
M
Myauk
EMC issues become more and more important these days, according to my
understanding.
For Home Theater System DVD Players I would like to know whether cable
dressing after sercice should follow strict procedures or not.
D
D from BC
understanding.
Crank up the gain and if you hear too much noise on the softest sound
from a DVD (if you really need to hear it) then you have a problem.
Cable dressing after service??....wtf..That's some new audio jargon
for me.
You know all the fat is from the cable dressing not from the bowl of
cables... :p
D from BC
M
Michael A. Terrell
for me.
It sounds like he's looking for one of those fetish newsgroups.
cables... :p
D from BC
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
D
Don Lancaster
M
Michael A. Terrell
Don said:
Your cables should be IMMEDIATELY replaced by four-point barbed wire!
See http://www.tinaja.com/glib/marcia.pdf for detailed instructions.
Well, that's a start but you left out the most important steps: the
barb wire has to be soak in a fresh citric acid bath made from Florida
oranges. They have to be picked between 7:10 AM and 9:00 AM, and only
from the northern edge of the grove. The acid has to be extracted, then
heated to 142 degrees F by 10:15 at the latest. Then the wire has to
soak for exactly 27 seconds in a vat that holds 42 gals of acid, per
pound of treated wire. This micropickels the surface to remove the
surface slag, which chokes the low end. NEVER reuse the acid for a
second batch of wire.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
R
Rich Grise
Don't forget to compensate for the phase of the Moon. ;-)
Cheers!
Rich
