home theater soud problems
Discussion in 'Electronic Equipment' started by alindsey, Jun 20, 2005.
  1. alindsey
    alindsey Guest
    My Panasonic home theater system pretty much works great. However, quite
    frequently the sound is interupted by a popping static sound. Does anyone
    know how to help? Any advice would be appreciated.
  2. There are many audio-related newsgroups, to which this question would be
    much better suited. This particular newsgroup is mainly concerned with
    electronics test equipment, as you can see if you read a few of the
    postings, which is never a bad idea before posting to a group.
    That said: one possibility is that it is caused by a spike on your power
    line. If your hifi is on the same circuit as something with a motor in it -
    for instance, a refrigerator or air conditioner - then whenever that motor
    turns on or off, there will be a short voltage spike.
    You may be able to get relief by using a surge arrestor or an isolation
    transformer; or by shifting the system or the offending appliance to a
    different electric outlet.
