R
Rich Grise
HP5245L counter with various plug-ins.
Heck, get a 10 MHz crystal and _build_ a counter, for heaven's sakes!
Then, you can build a 10 MHz TRF receiver and calibrate your counter
to WWV.
Cheers!
Rich
to WWV.
mc said:My HP counter (don't remember the model, probably older than yours) has a
10-MHz output. That, plus an NE602, plus my ham radio antenna, and not much
else, makes a receiver to tune WWV and calibrate the counter to sub-1Hz
precision. I seem to recall using a 10.7-MHz FM IF transformer as the input
coil.
coil.
Phil said:Now _that_ is a fun idea--bootstrap city. If I run a long wire across
my back yard, I can probably get several dB gain at 10 MHz, if I orient
the lobes right (gotta find that strategically-placed tree). Have to
find a good project that needs that much precision and is a kid magnet.
Radioscience is an obvious idea, but radio is _so_ retro nowadays.
Cheers,
Phil Hobbs
So which of your favourite old instruments have I forgotten?
Cheers,
Phil
Rich Grise said:Then, you can build a 10 MHz TRF receiver and calibrate your counter
to WWV.
Ken Smith said:It doesn't have to be a TRF. You can use any old receiver. You just have
to offset the calibration point from 10MHz by lets say 1KHz.
When the counter indicates a 1KHz audio for a 10.001MHz generator
measurement, the counter is calibrated.
mc said:I wonder if by TRF he meant direct-conversion.
Anyhow, you can also use a superhet, and you don't have to offset the
calibraiton point. Tune your regular shortwave radio to WWV at 10 MHz and
turn the frequency counter on. Feed a little of its 10 MHz output to the
area of the radio. You'll hear a heterodyne. Adjust as near 0 Hz as you
can get. When it gets below about 30 Hz you won't hear it; instead you'll
see the S-meter bobbing up and down. Make it bob as slowly as possible.
Phil Hobbs said:Well, after raising two very fine daughters who both turned out to be
gifted in fuzzy subjects such as languages and history and bunk like
that, my son is showing signs of technical aptitude and interest.
Therefore, I'm putting together a lowish-budget home lab off ebay, with
an eye to doing some Jacob's ladders or Tesla coils or stuff like that
there, with maybe an electro-optical thing now and again, such as a
machine to detect deer and hit them with paintballs.
Ken Smith said:Probably - when I learned it, it meant "tuned radio frequency" - it's justI wonder if by TRF he meant direct-conversion.
a tuned circuit, maybe an RF amp, and a detector of some kind. I suggested
it because it seems like a good beginner-level project - maybe because the
first thing I ever made with a transistor was an AM radio.
Cheers!
Rich
martin said:What sort of mechanical tools do you have?
A descent bench vice, pillar drill and assorted blunt drills
and a variac
dated Thu said:We'll probably try phase-locking. Building a 10-MHz VCXO will be a
good project--especially using a 2N3904 for a varactor.
Chris said:Phil Hobbs wrote:
Variacs are fun for experimenting with motors, electromagnets, small coil
guns, Jacob's ladder etc., make sure it has a circuit breaker or fuse that
will protect the variac and make sure you have an earth leakage (or
whatever you call them) breaker for the bench to cut it off if anyone gets
a shock of the kind that one of those can detect (but it won't help for the
Jacob's ladder).
Chris
Phil said:Good point. Don't have enough of those things, especially no drill
press. I have a Panavise and hand drills, but that isn't the same.
Variacs I've been looking at, but I'm mostly going to be starting from
good-quality DC power, at least initially, so I can do the "gradual
smoke test" with the panel knobs.
Cheers,
Phil Hobbs
Ken said:Ken Smith said:[...]
to WWV.
I think he was using it for "Tuned RF". This was how tube radios were
made before Armstrong came up with the superhet.
This requires that you have an S-meter. The offset frequency method
doesn't. You can get a very accurate calibration that way. If your
counter has a "period" mode, you can get many digits.
Ken said:[...]
to WWV.
Use your scope in X/Y mode for a better indicator.
Ken said:With WWV as a reference this doesn't work very well. You need to narrow
band filter the WWV to get rid of noise far from the carrier. This is
most easily done by using an existing radio.
BTW:
With a dual channel scope, you can trigger from one and observe the
other in the usual Y vs T mode and get the same effect. You tune for the
waveform not moving.
This is handy for adjusting 32786 oscillators without actually connecting
the probe to them. You just hold the probe a small distance away and turn
the vert. of the scope all the way up.
