Home energy monitors, part 2
Discussion in 'Electrical Engineering' started by Dave Martindale, Feb 13, 2008.
  1. A few weeks ago, I wrote about the UPM EM-100 energy meter. After
    trying it, I ordered a P3 Kill-a-Watt model P4400, and it arrived this
    morning.
    At first glance, the Kill-a-Watt is the better tool for anything but
    resistive loads. It does understand the difference between watts and
    VA, and will display either along with power factor. The unloaded
    isolation transformer that draws "20 W" according to the EM-100 uses 7 W
    and 20 VA according to the Kill-a-Watt, with a power factor of 0.33.
    (BTW, is this a typical power factor for transformer magnetizing
    current? I don't have any other meters that measure PF, so I don't know
    what's typical. A 0.33 PF is a 70 degree phase shift.)
    In addition, the Kill-a-Watt manual explicitly says that the volts and
    amps measurements are RMS. The UPM manual doesn't seem to say one way
    or the other, so its V and A display are probably based on average
    measurements, not RMS. I haven't yet tried them with a load that has a
    weird current waveform to see if they differ.
    On the other hand, the UPM meter has a number of user conveniences that
    the basic Kill-a-Watt lacks. Here's a comparison:
    P3 P4400 Kill-a-Watt
    * RMS V and A measurements
    * Calculates and displays W, VA, and PF
    * Measures frequency in Hz
    * Cumulative kWh and total time (plugged in)
    * Line powered; a power failure loses all cumulative data
    UPM EM-100
    * V and A are probably not RMS
    * Calculates VA only (and calls it W)
    * no frequency
    * Cumulative kWh and total *running* time (time current is not zero)
    * Battery powered; no loss of cumulative data with power failure
    * Records peak A and peak VA since last reset
    * If you program your cost/kWh, it converts cumulative kWh to dollars
    for you.
    Having the cumulative time be running time for the device, rather than
    total elapsed measurement time, means you can calculate average running
    watts of a device like a refrigerator. Similarly, peak current might be
    interesting.
    There is also a P4460 model Kill-a-Watt that adds battery backup and
    dollar cost functions, though it's somewhat more expensive. I haven't
    tried it.
