B
Brent Geery
Could someone point out how to go about predicting the cooling
capacity I'll need for a super insulated "cabin" in the So. Cal.
desert?
The structure will be about 450 sq. ft. one story structure, about
25'x20, using a slab-on-grade foundation, with a
double-wall/staggered-studs metal design, to give me the depth
necessary for the insulation, and act as a thermal break between the
outside and inside. I will be using metal studs throughout, on 24"
centers (between the inner and outer wall, give effectively 12"
spacing.) R-42 insulation in the walls, and R-84 in the attic. The
roof will be metal with white baked finish metal "cool roof/double
roof design, with an additional radiant barrier under the rafters.
Attic ventilation will be full ridge. Siding will be white vinyl.
Windows being one each on the north and south side, 3'x3' double
glazed low-e with argon fill, and one on the east side, 1'x2' double
glazed low-e with argon fill. Extra special care will be given to
eliminating all breaks in the vapor barrier envelope. The main entry
door will probably be fiberglass, with a foam core. I am thinking of
having a double-entry door, to decrease the heat transfer through the
entryway. Have I missed anything?
The nearest Solar data for my construction site is Dagget, CA, the
links to the comma separated values spreadsheets are:
http://rredc.nrel.gov/solar/old_data/nsrdb/bluebook/data/23161.SBF
http://rredc.nrel.gov/solar/old_data/nsrdb/redbook/sum2/23161.txt
Originally, was going to go with a cool tower/thermal chimney combo
for cooling, but with the low cost of off-spec PV on a two-axis
tracker, I'm thinking of going with a conventional AC, and offsetting
the extra PV costs with lower construction costs (would cut about
1/3-1/2 the materials cost!) and much simpler construction 1 story
construction (good bonus, as it's being 100% owner-built). I'm hoping
a 5000 BTU AC will be more than enough capacity, and only have to run
a fraction of the time, even on a record-setting 115-120 degree day.
Please help me understand how to calculate what I need, based on my
assumptions above, and using the data available at the above links.
desert?
