HM 10 range problem..?
Discussion in 'Microcontrollers, Programming and IoT' started by iqbalpalemad, Nov 2, 2016.
  1. iqbalpalemad
    iqbalpalemad
    3
    Nov 2, 2016
    Hai
    i am using a hm10 ble module in my project.But the range is too short than i expected so i need to increase the range so can i i increase the range by adding an external antenna if so how can i do that
  2. davenn
    davenn Moderator
    13,496
    1,830
    hi
    welcome to EP
    BT is designed to me low power and short range, 5 - 10 metres is typical
    what range are you getting ?
  3. iqbalpalemad
    iqbalpalemad
    3
    Nov 2, 2016
    but the specification says it will work upto 100m but i am getting a range of 14M
  4. JWHassler
    JWHassler
    78
    16
    Dec 22, 2014
    Have you set the power-level to +6dB? The default is 0dB
  5. davenn
    davenn Moderator
    13,496
    1,830
    I have been through a dozen www sites and none of them state a distance ..... I suspect 100m is garbage and the 14m is more accurate
    that's still only 4mW and isn't going to do 100m
  6. duke37
    duke37
    5,297
    739
    Jan 9, 2011
    Depends on the frequency but a parabola behind the device with the device 'looking' into the parabola will help.
    I have had a transmitter on 27MHz using a 2N706 at about 10mA being picked up at several miles, just a quarter wave vertical each end.
  7. davenn
    davenn Moderator
    13,496
    1,830
    the standard for BT is 2.4 GHz
  8. duke37
    duke37
    5,297
    739
    Jan 9, 2011
    Does
    Does that mean the wavelength is about 125mm?
    If so a set of 60mm rods set in a parabola with the Tx/Rx at the focus should increase the signal in one direction.
    davenn likes this.
  9. iqbalpalemad
    iqbalpalemad
    3
    Nov 2, 2016
    can you tell me how to set the power level to +6dB...?
  10. davenn
    davenn Moderator
    13,496
    1,830
  11. Amar Dhore
    Amar Dhore
    129
    12
    Dec 2, 2015
    I had the same problem with my BT, the range was very short and the problem turned out to be Bluetooth module was not mounted on PCB as per the specification. If you are using a surface mount module, just make sure you PCB mount is as per the specs.
