Hitachi v152F probe 1 trace is flatline no change in trace
Discussion in 'Electronic Repair' started by Don, May 29, 2013.
  1. Don
    Don Guest
    Probe 1 doesnt respond to any input..., ch 2 seems ok.
    BNC connector was loose and wire to resistor broke loose
    +Wire from resistor to BNC connector was re soldered nut tightened
    to BNC, and was working fine. Repair still looks good but
    ch 1 trace just a flat line can only adjust location of flat line.
    afraid to adjust internal pots in fear that I am making things worse.
    Channel 2 is working good responds to testing and calibration
    and internal pot adjustments. more in depth repair? or More aggressive
    adjusting? any thoughts?
    +-----------[ SERVER SIGNATURE ]-----------
    | posted via http://www.electrondepot.com
    | Web, RSS and Social Media Interface to
    | sci.electronics.repair and other groups
  2. N_Cook
    N_Cook Guest
    Blown first transistor or corrossion in one of the attenuator switch
    actions, no pot twiddling will resolve it.
    Can you swap a screened lead somewhere inside ? like checking left and right
    amps of a stereo unit
  3. Guest
    OHMMETER
    Does it read a short ?
