Hitachi AP62 Chassis Flyback Needed
Discussion in 'Electronic Repair' started by Shoreline Electronics, Jan 28, 2006.
  1. Make : Hitachi
    Model : 60FX32B
    Chassis : AP62
    Need a flyback for this set
    Numbers on flyback are : 2436493A & HFL1735HP
    Anyone got a good pull from the boneyard? One on the shelf?
    Jeff Stielau
    Shoreline Electronics Repair
    344 East Main Street
    Clinton,CT 06413
    860-399-1861
    860-664-3535 (fax)
  2. I may have one, Jeff, but I won't be back by the shop until Monday. I'll
    check then.
  3. Appreciate it! Thanks Len!
    Jeff Stielau
    Clinton,CT 06413
    860-399-1861
    860-664-3535 (fax)
  4. Turns out the blue CRT was defective !
    Running the HV section on the Sencore setup , collector pulse was ringing
    and distorted...just like a bad flyback. Did a little more digging to be
    sure. CRT checks bad and arcs inside neck when testing. Set will run with
    the CRT disconnected
    Jeff Stielau
    Clinton,CT 06413
    (860)399-1861
    (860)664-3535 FAX
