Hitachi 50UX15K won't turn on
Discussion in 'Electronic Repair' started by [email protected], Dec 24, 2006.
  1. Guest
    I know I am in way over my head, but with the price of HDTV dropping
    like a rock, I simply cannot justify spending the money to have someone
    else fix my Hitachi 50UX15K. So I thought I might try it myself, but I
    don't know exactly where to start. I do know enough about this stuff
    to know that I *CAN* kill myself because of the high voltage around the
    tubs. Thus I know to be VERY careful and not to touch anything that
    looks like something that could kill me, which looks like most
    everything bigger then a fuse;)
    Here is what I know: When I turn on the power, I here the normal
    "click" but the LED on the front ever comes on. There was no
    indication that anything was going wrong, it simply stopped displaying
    a picture on day.
    Is anyone willing to give me some suggestions on things I could look at
    which might be a simple fix to the TV? Are there common fuses that
    burn out, components that I can check visually? etc? Thanks!
  2. There are a number of green LEDs in the set on the circuit board and one red
    one. What do they do when the set is plugged in and when the power is
    switched on? Which ones come on, in what order, and for how long?
    Leonard
  3. Meat Plow
    Meat Plow Guest
    No offense but you're not goingto fix it on your own.
  4. kip
    kip Guest
    I agree !!
    frank
  5. Guest
    Leonard,
    I looked all over and did not see any LED's of any sort. I did turn
    the TV on a number of times and never saw anything light up.
    When viewing from the front it looks like all the high voltage
    components are on the left and the low voltage components are on the
    right. It also looks like there are two virtical circuit boards on the
    back left. Oh, there is also the one on the front panel to adjust the
    tubs and the little one behind the buttons on the front.
    Where exactly should I be looking?
  6. Guest
    No offense taken. To tell you the truth, I don't think I can do it
    either, but the one thing I know, if I don't try I most definitly
    cannot do it;)
  7. kip
    kip Guest
    Support your Local TV Tech and call him...
    Because one day YOU will need him.
    kip
  8. Meat Plow
    Meat Plow Guest
    Cool, I discourage everyone who has no formal training from sticking their
    hands in something that can generate up to 32 thousand volts. Granted the
    high voltage is low amperage and that I have survived many "bites"
    however, there are other more hefty supplys well above 110 volt house
    current (US) that could cause you serious injury or detah. I sure wouldn't
    ever offer advice to someone like you other than leave it alone.
  9. Guest
    Kip,
    I would in a heart beat, if I had it, I don't. Why else do you think I
    am trying to save a 13-year-old TV;)
  10. Bob Shuman
    Bob Shuman Guest
    I had the same model with the same symptoms repaired about 9 months back for
    about $350. I know it seems like a lot for a 13 year old set, but it still
    has a great picture and my family loves it so it was worth it to me. My
    only advice is to find someone who has experience with the Hitachi. It is a
    well made set and probably worth at least getting a quote for repair.
    If you do elect to dump it and are willing to pull the CRTs and boards, let
    me know since finding replacement parts is getting pretty tough on mine due
    to its age!
