Hitachi 50" RPTV Startup Problem
Discussion in 'Electronic Repair' started by Crew Dawg, Dec 23, 2003.
  1. Crew Dawg
    Crew Dawg Guest
    I purchased a Hitachi C50-FD2000 HDTV/RPTV three months ago. This set
    is an Asian model made in Japan. Within the past week, the set has
    occasionally, 2 times out of 10, had an intermittent picture on
    startup which will go away after 2 to 5 minutes. The unit will then
    run for hours without a problem and the overall picture quality is
    really great! This problem occurs with different input sources such
    as DVD and satellite with a room temperature of around 75 to 85F.
    I wouldn't think it would make any difference which unit I power up
    first on startup/shutdown but I may be wrong. Any ideas?
    My tech support will come from Manila which is around three hours
    travel time from where I live in Angeles City, so I would greatly
    appreciate any comments that might help me troubleshoot the problem.
    Thanks in advance!
  2. Jerry G.
    Jerry G. Guest
    It sounds like a component on one of the scan circuits or power supply is
    thermo sensitive, or something like that. The tech will have to troubleshoot
    the set for a thermo problem if this is the case. This type of fault can be
    tricky to find.
    Greetings,
    Jerry Greenberg GLG Technologies GLG
    WebPage http://www.zoom-one.com
    Electronics http://www.zoom-one.com/electron.htm
    Thanks in advance!
