M
Michael D. Harmon
I recently picked up an old Allen "high tension tester" at at the local
electronics emporium. It was originally designed for checking
automotive HV electrical systems, and is basically a hipot using a
vibrator(!), a 6V ignition coil, and a 1B3 rectifier tube to generate
0-15,000 V at a few uA. It was powered by a 6V. 12V, or 24V battery.
The output voltage was controlled by a rheostat in the coil primary.
The caps in the thing were old wax-paper aluminum-foil 50's vintage
units, and the HV leads were old stiff rubber spark-plug wire. I did
get a couple of excellent-condition panel meters as well as the HV glass
multiplier resistors
I'm planning to redesign this thing for 117VAC, using silicone spark
plug wire for the HV leads. I still need to keep the variable output
capability. I'd also like to incorporate some sort of current limiting
capability to reduce the death-factor.
Anyone have any ideas for an effective, yet relatively simple way to
generate 0-15,000 KV DC at say 50 uA or less? I've thought of several
ways of doing this. The first is simply using the same basic design,
but replacing the vibrator with a solid-state triggering circuit and the
1B3 TV rectifier tube with oscilloscope HV diodes. Another was to use a
HV transformer(neon?) and a small Variac. Still another was to use a
surplus flyback, but those things have a bunch of unknown leads sticking
out the bottom (and no diagram!). I'd still have to come up with a
trigger oscillator/driver however.
I'm open for suggestions!
Mike Harmon, WB0LDJ
[email protected]
Mike Harmon, WB0LDJ
[email protected]
