high voltage PNP
Discussion in 'Electronic Components' started by Scott Seidman, Apr 25, 2008.
  1. I can't seem to find any pnp transistors with a Vce bigger than 500V. I'd
    like one that can go to 1K for use with a current sense. Any pointers??
  2. legg
    legg Guest
    Wrong decade, wrong technology. Think of another way.
    If linearity is not required (ie limiting only) think of
    amplitude-triggered communication methods. They aresimpler to develop.
    RL
  3. I'm trying to find a bigger transistor to use with the AD8212 High Voltage
    Current Shunt Monitor. Adding the external transistor buys me a common
    mode voltage capablility of Vce, totally braindead, but I can't find
    anything greater than 500V.
  4. Joerg
    Joerg Guest
    Looks like the FMMT560 with 500V is pretty much the end of the rope when
    it comes to commonly available parts. The IXTH10P60 goes to 600V but
    it's a (largish and expensive) p-channel FET.
  5. legg
    legg Guest
    So you need linearity, huh.....?
    Try sticking your AD8212 output collector's constant current through
    the source of a p-channel fet, with the fet gate on the AD8212
    'common' terminal. I assume you're getting well-decoupled power from
    somewhere to run this thing. That should give current info over the
    fet drain's compliance, if the added capacitance can be suffered at
    the receiving end.
    There are also methods of stringing 'transmitters' in series, with
    their bases (or gates) on a HV divider. Each collector feeds an
    emitter (or source) farther down the resistive divider.
    Being brain dead isn't something you should be aiming to achieve,
    despite what your boss tells you.
    RL
  6. legg
    legg Guest
    See a pdf swcadiii model illustrating a sensor using the pnp bipolar
    string on abse.
    RL
    Version 4
    SHEET 1 880 680
    WIRE -304 -32 -432 -32
    WIRE -144 -32 -304 -32
    WIRE -48 -32 -144 -32
    WIRE 96 -32 32 -32
    WIRE 240 -32 96 -32
    WIRE 320 -32 240 -32
    WIRE 480 -32 320 -32
    WIRE 560 -32 480 -32
    WIRE 240 0 240 -32
    WIRE -144 16 -144 -32
    WIRE -16 16 -144 16
    WIRE 320 16 320 -32
    WIRE -304 32 -304 -32
    WIRE -304 32 -320 32
    WIRE -272 32 -304 32
    WIRE -432 48 -432 -32
    WIRE -320 64 -320 32
    WIRE -272 64 -272 32
    WIRE -48 64 -176 64
    WIRE 96 64 96 -32
    WIRE 96 64 32 64
    WIRE -144 112 -144 96
    WIRE -80 112 -144 112
    WIRE 48 112 -80 112
    WIRE 80 112 48 112
    WIRE 320 112 320 96
    WIRE 320 112 160 112
    WIRE 320 128 320 112
    WIRE -16 144 -16 16
    WIRE -320 160 -320 128
    WIRE -288 160 -320 160
    WIRE -272 160 -272 128
    WIRE -272 160 -288 160
    WIRE -80 160 -80 112
    WIRE -48 160 -80 160
    WIRE 48 176 16 176
    WIRE 144 176 48 176
    WIRE 240 176 240 80
    WIRE 240 176 224 176
    WIRE 256 176 240 176
    WIRE 480 176 480 -32
    WIRE -432 192 -432 128
    WIRE -176 192 -176 64
    WIRE -48 192 -176 192
    WIRE 560 192 560 -32
    WIRE -288 240 -288 160
    WIRE -192 240 -288 240
    WIRE -48 240 -192 240
    WIRE -16 240 -16 208
    WIRE -16 240 -48 240
    WIRE 208 240 176 240
    WIRE 320 240 320 224
    WIRE 320 240 272 240
    WIRE -48 256 -48 240
    WIRE 320 256 320 240
    WIRE 176 304 176 240
    WIRE 256 304 176 304
    WIRE -192 336 -192 320
    WIRE 176 336 176 304
    WIRE 176 336 -192 336
    WIRE 320 368 320 352
    WIRE -432 448 -432 272
    WIRE -192 448 -192 416
    WIRE -192 448 -432 448
    WIRE 320 448 -192 448
    WIRE 480 448 480 256
    WIRE 480 448 320 448
    WIRE 560 448 560 256
    WIRE 560 448 480 448
    FLAG -48 256 0
    SYMBOL Opamps\\LT1366 -16 112 R0
    WINDOW 0 23 122 Left 0
    SYMATTR InstName U1
    SYMBOL res -160 0 R0
    WINDOW 3 36 36 Left 0
    WINDOW 0 -43 35 Left 0
    SYMATTR Value 4K99
    SYMATTR InstName R1
    SYMBOL res 176 96 R90
    WINDOW 0 0 81 VBottom 0
    WINDOW 3 -27 27 VTop 0
    SYMATTR InstName R2
    SYMATTR Value 100K
    SYMBOL res 240 160 R90
    WINDOW 3 -27 42 VTop 0
    SYMATTR InstName R3
    SYMATTR Value 1K
    SYMBOL res 304 0 R0
    WINDOW 0 46 25 Left 0
    WINDOW 3 41 57 Left 0
    SYMATTR InstName R4
    SYMATTR Value 10K
    SYMBOL res 48 48 R90
    WINDOW 0 -1 87 VBottom 0
    WINDOW 3 -27 24 VTop 0
    SYMATTR InstName R5
    SYMATTR Value 4K99
    SYMBOL res 336 464 R180
    WINDOW 0 36 76 Left 0
    WINDOW 3 36 40 Left 0
    SYMATTR InstName R6
    SYMATTR Value 10K
    SYMBOL res -176 336 R180
    WINDOW 0 -44 71 Left 0
    WINDOW 3 -57 38 Left 0
    SYMATTR InstName R7
    SYMATTR Value 220K
    SYMBOL cap -288 64 R0
    SYMATTR InstName C1
    SYMATTR Value 1E-8
    SYMBOL cap 32 112 R0
    WINDOW 0 24 18 Left 0
    WINDOW 3 19 49 Left 0
    SYMATTR InstName C2
    SYMATTR Value 1E-10
    SYMBOL zener -304 128 R180
    WINDOW 0 24 72 Left 0
    WINDOW 3 -62 -51 Left 0
    SYMATTR InstName D1
    SYMATTR Value BZX84C10L
    SYMBOL res 48 -48 R90
    WINDOW 0 57 91 VBottom 0
    WINDOW 3 30 45 VTop 0
    SYMATTR InstName R8
    SYMATTR Value .05
    SYMBOL res 464 160 R0
    SYMATTR InstName R9
    SYMATTR Value 400
    SYMBOL cap 544 192 R0
    SYMATTR InstName C3
    SYMATTR Value 47E-6
    SYMBOL voltage -432 176 R0
    WINDOW 3 -35 299 Left 0
    WINDOW 123 0 0 Left 0
    WINDOW 39 0 0 Left 0
    SYMATTR Value PWL(0 0 1E-3 400 2E-3 395 3E-3 400 4E-3 395 5E-3 400)
    SYMATTR InstName V1
    SYMBOL voltage -432 32 R0
    WINDOW 3 -58 -17 Left 0
    SYMATTR Value SINE(0 1 2500)
    SYMATTR InstName V2
    SYMBOL pnp 256 224 M180
    SYMATTR InstName Q1
    SYMBOL res 224 -16 R0
    SYMATTR InstName R10
    SYMATTR Value 10K
    SYMBOL pnp 256 352 M180
    SYMATTR InstName Q2
    SYMBOL res -208 320 R0
    WINDOW 0 42 44 Left 0
    SYMATTR InstName R11
    SYMATTR Value 220K
    SYMBOL diode 208 256 R270
    WINDOW 0 32 32 VTop 0
    WINDOW 3 0 32 VBottom 0
    SYMATTR InstName D2
    TEXT -464 504 Left 0 !.tran 0 6E-3 2E-5
