- Joined
- Jan 21, 2010
- Messages
- 25,510
- Keep one hand in your back pocket
- Don't bridge capacitor leads with a conductor
- Don't touch any point of the circuit with a probe or connector not insulated against 100kV
4) Don't work alone.
5) Work in a clean and tidy environment
6) Connect all test equipment before powering on, and power off (and discharge) before disconnecting.
7) Have bleed resistors etc where appropriate to bleed off charge.
8) Ensure all aspects of your test equipment is rated for the maximum voltage.
9) Have someone else review your safety procedures.
10) Have a kill switch that will remove power from everything for someone else to use if you're lying on the floor twitching or for you to use if smoke starts coming out of something.
11) always assume high voltage capacitors are charged -- even when you know they're not. The exception is when they have a shorting strap across them.
