D
David L. Jones
David L. Jones ha scritto:
4KV on PCB (Esd Test)
Trust me, that PCB would have fried chips long before that spark gap
voltage would ever get reached.
CMOS can get killed with as little as a few volts, and typically get
killed by less than 30V.
Just raising your arms in the air in a dry lab with no ESD smock on
can generate that much differential.
Peter Parker said:Lower voltage, but with petrol added:
2.2KV is for girly men, try 500KV...
HOLY SHIT!!!!!!!
That is absolutely AMAZING!!!!!!
Burned enough power in that one run to power a town.
YouBOOB is lame. That clip was longer, and every time some tard
uploads it, it gets snipped back further and further.
No, it didn't "burn power" Whatever load was on the load side of
that switch still got fed while the plasma was arcing.
Rich said:Some months or years ago, someone gave a detailed description of what
exactly happened - there are actually two switches there, and you can
actually see the thing just to the right of the arc terminal burn up;
this contributed to the big arc - I don't remember exactly what that
first failed part was - some kind of arc quencher that failed, I think.
I'd look it up, but google groups search is way broken, so it's not even
worth the bother.
Maybe somebody else remembers.
Rich
worth the bother.
Rich Grise wrote:
The script kiddies have D/L'ed that from our site and uploaded their
copies countless times on You Tube and Google - for the straight story
on this clip see http://arcs.teslamania.com
MassiveProng said:I seem to remember that it was a three phase switch, and all three
were supposed to open, and only one did.
The grid banging transformer fire/explosion was a pretty good video
too. Wouldn't want to be within a hundred feet of that one...
on this clip seehttp://arcs.teslamania.com
Post the links again, and I'll give you a pretty detailed description.
I think I've seen both of these.
MassiveProng said:Read back through the thread, dipshit.
Hey. I offered to help. You told me to piss off. Goodbye.
