High Vce(on) with an IGBT - 100kHz smps
P
Pooh Bear
I'm currently using a pair of IGBTs in my prototype smps ( UC3525
controller - half bridge configuration with IR2110 driver ).
It's up and running nicely now after the kind help here.
I've been testing it with some dummy loads to check device dissipation
and current waveforms ( just a large R across the bridge directly or
coupled by a 1:1 TX ).
At a load of ~ 600W I was surprised by the temp rise in the IGBTs. Makes
no difference if the load is transformer coupled or not btw.
Looking at the Vce of the lower device whilst on, I saw about 8V.
According to the datasheet ( it's an Infineon SGW30N60 btw ) with the 4A
or so it's carrying, Vce should be < 1.5V. High side device appears to
dissipate the same. Temp rise seems to correlate with the heatsink
thermal resistance ( 3C/W) and the calculated dissipation.
Gate drive voltage is ~ 14 V. Waveforms look clean to me.
Now the puzzling bit. I removed the big load but a small load ( actually
33k ) remains. Vce(on) remained at 8V !
It should be *very close* to ground. Any clues why not anyone ?
Device on-time is ~ 4 us and dead time ~ 1us currently.
Graham
F
Fritz Schlunder
Are you saying the thermal dissipation isn't outrageously high, but the
Vce(on) appears very high even so?
Make sure your oscilloscope isn't lying to you. When off the IGBT blocks a
huge amount of voltage, but when on the voltage becomes very small. On the
small scale needed to measure Vce(on) the oscilloscope may not work properly
due to the extreme high voltage at other times.
Try measuring Vce(on) through say a resistor and a low voltage zener diode
to clamp the maximum peak voltage to something small like 10V. Keep in mind
the resistor plus zener and probe capacitance make a low pass filter which
will degrade measurement bandwidth.
W
Winfield Hill
Pooh Bear wrote...
Makes no difference if the load is transformer coupled or not btw.
4A or so it's carrying, Vce should be < 1.5V. High side device appears
to dissipate the same. Temp rise seems to correlate with the heatsink
( actually 33k ) remains. Vce(on) remained at 8V !
Did you swap out the part? Sounds damaged.
T
Terry Given
drop the switching frequency down to, say, 1kHz where you can completely
ignore the switching losses (Lmag may need to be cranked up, or Vdc
reduced to compensate).
thats a seriously crap Vce. there cant be too many reasons:
- measurement is wrong
- Vge is way too low
forget 1kHz, do it at DC - turn the bottom IGBT on, and slam some
serious current thru it. Easy to measure Vce then, esp. when Vdc is low.
good point - scope thermal tails due to overdrive.....
i've built compensated dividers clamped with 4148s for this job.
Cheers
Terry
P
Pooh Bear
No problem there. Excellent idea. I can hang the load directly across the bridge
anyway since the tranformer ratio is 1:1 anyway.
Indeed !
I've been musing over that. And how - why.
14V seems ok to me.
I can do that too I guess.
Hadn't explicitly considered scope issues but had a nagging feeling. Interesting
one. I can see the sense in that.
I'll check the probe C. A 10:1 probe should be fairly ok. I could even use a 100:1
probe. That's about 4pF IIRC.
Ahhh - ok I got it. Clamp the voltage you're measuring to something that's not
over deflecting the scope basically.
Cheers guys, Graham
P
Pooh Bear
Winfield said:
Pooh Bear wrote...
That would have been tomorrow's ( today's now ) job. In fact I was thinking
of swapping in a Mosfet with about 200~300mOhm Ron. That should certainly
have illustrated any measurement technique error.
I don't think the part is damaged though.
Also just occured to me that if Vce is really 8V then Vboot for the IR2110
would be degraded by that amount too and I can measure that directly.
Cheers, Graham
L
legg
Check your probe's AC calibration at a similar frequency, using a
lower amplitude signal.
Don't overdrive the scope's input amplifier.
RL
T
Terry Given
Indeed !
14V seems ok to me.
Cheers guys, Graham
bingo. kind of crap, but better than nothing. I forget the vendor, but a
Tektronix spin-off makes beautiful broadband diff probes for exactly
this job. $$$$ :(
linear tech's AN47 talks about it in detail
Cheers
Terry
T
Terry Given
yep.
If Rg was much higher than expected, Cge//Cmiller could cause the
waveform to "average" out at 100kHz. winding Fs down would show that, as
would a decent floating gate drive measurement. A tek P5200 would help..
another possibility is a nice big flat spot in the Vge waveform, where
Cmiller fights with Rg. If you say use 0603 Rgs and them snot them with
gate charging pulses they can go high.....
P
Pooh Bear
That would appear to be the lesson here.
Graham
P
Pooh Bear
Terry said:
yep.
I wish ! ;-)
Haven't seen that.
It's all leaded parts and I used 1/4W rather than 1/8W here. Saw that one as a
possibility at least ! I think I even modelled the series Rg dissipation even !
Graham
B
Ban
appears to dissipate the same. Temp rise seems to correlate with the
heatsink thermal resistance ( 3C/W) and the calculated dissipation.
Graham
How are you driving the IGBTs? The gate resistor should be 11R, with a 3A
schottky parallel for faster turn-off. The2113 driver is also better for
FETs only, I would rather have a negative gate voltage for turn-off.
What you see is probably shoot-through current because of the slow turn-off.
Then 200kHz is way too high for IGBTs, this size stay below 40kHz. Look at
the data sheet figure1.
T
Terry Given
Pooh said:
Terry Given wrote:
I wish ! ;-)
Haven't seen that.
Graham
sometimes Pavg is an issue, but usually not until F is high or the IGBT
is huge (100nF Cge anyone?)
Ppeak is more likely a problem, but 1/4W leaded Rs should eat a few tens
of watts peak. if RgCge > Trise then Ppeak reduces too. the calc is
easy, and spice is trivial.
Cheers
Terry
P
Pooh Bear
I have 10R.
with a 3A schottky parallel for faster turn-off.
I have a fast diode ( not shottky ) in parallel. Where do you get the 3A figure
? Turn off looks very clean btw.
The2113 driver is also better for FETs only, I would rather have a negative
Understood, but this is what I have currently. Examination of a well-known
product with similar design shows this to be adequate.
I've seen the considerably older IRG4PC50U used in exactly this configuration
with zero problems.
Yes, I've looked at Fig 1. I don't expect Tc to exceed 80C ( I hope ). That
would appear to be good for ~ 25A = ~ 3.7kW output. It won't be a continuous
requirement on account of the nature of the psu ( high instantaneous peak
requirement - lower average requirement ).
Graham
T
Terry Given
fig. 14 shows Eon and Eoff both have similar slopes wrt Rg, so although
a lower Rgoff has more effect than lowering Rgon, the difference isnt
huge. Off delay is greatly reduced with smaller Rgoff though (but it
only fiddles with pulse width, and has little bearing on losses)
With Rg = 0R, fig. 14 shows total switching energy Ets = 1.5mJ for
inductive 30A load, so at 4A, 100kHz thats 200W. Hmm, thats pretty high.
It fits with Bans comment re. fig 1 though - current wants to be pretty
darned low at 100kHz.
I have played a few times (mostly analytically, a few experiments) with
these so-called "fast" little IGBTs, at around 100kHz. every time a 600V
FET won hands down, due to switching losses. To be fair I havent
exhaustively tested little IGBTs, having given up after the 3rd or 4th try.
Cheers
Terry
T
Terry Given
Pooh said:
Ban wrote:
I have 10R.
with zero problems.
Vth worst case is 2V. Your gate driver output wont pull to 0V, the
difference between the two is your noise margin. emitter-followers would
not be a great idea here.
lets pretend Vgd = 0, then Cmiller has to force a 2V spike into Zg =
Cg//(Rg + Lg). This is where Lg can get you into trouble. using a -ve
bias means the noise margin = Vth + |V-|, allowing a much higher Zg.
Rg is low, but if the dV/dt is occurring in say 20ns, then Fknee = 16MHz
= 100Mrad/s, and 10R == 90nH. your leaded resistor has 10-20nH all by
itself, the gate lead adds another 10nH or so *as does* the emitter
lead, then there is the rest of the loop, the IRxxxx bond wire etc.
admittedly a crude analysis, but the problem is real.
a simple test for cross-conduction is a small, low-inductance resistor
(or A6302 current probe) at the bottom of your dc bus cap. look for the
spike. Unfortunately this test can introduce enough inductance in the DC
bus to over-voltage the igbt.
another, less-intrusive shoot-thru test is to crank the dead-time up,
then measure light-load Tj as Tdead is slowly reduced (measure
steady-state Tj, reduce Tdead, continue until bang). When cross
conduction begins, Tj rises.
Graham
fig 1 is bullshit. For a start, fig. 4 shows a 40A DC current limit, due
to bond wire alone. if its 120A 150C Tj then fig. 6 gives Vce = 6V, for
Pon = 720W, IOW 360W average. yeah right. Then Ets = 4*1.6 = 6.4mJ,
shown flat to 40kHz - thats another 256W switching losses. So P_avg =
600W or so. with a 70C rise in Tj? Rtheta_total = 70K/600W = 0.12K/W,
five times less than Rtheta_j_c of the device alone.
Cheers
Terry
W
Winfield Hill
Terry Given wrote...
due to bond wire alone.
http://www.infineon.com/cgi/ecrm.dll/ecrm/scripts/public_download.jsp?oid=123828
No, both figures appear fine and self-consistent. Figure 4 is for the
DC case, which is more severely limited by temperature rise. Figure 1
(top trace) is for the peak current of a 50% duty-cycle sawtooth, as
they show in the inset. The short peak duration allows for higher peak
currents, especially if the frequency is above 1kHz (500us ramp, 500us
off). Figure 2 is another look, tying these together. Of course all
three assume Tc = 25C, which is impossible in operation, and Tj = 150C
at the graph's max, to which you might be unwilling to push the part,
so a severe derating would be in order when using any of these figures.
Figure 16 (transient thermal impedance) also ties them together.
Figure 1 is a nice plot that's rarely seen, and gives a valuable result
that's a bit hard to come up with on your own using the more common SOA
and transient thermal impedance information in figs 2 and 16. To create
fig 1, they'd need to have a fairly-complex well-tested thermal model,
or take lots of rather painful measurements. I say painful, because it
involves apparatus that the average joe, such as myself, doesn't have.
T
Terry Given
Hi Win,
the second trace on fig. 1 shows 120A 50% from 1-4 kHz at Tc = 80C, Tj =
150C. admittedly 2kHz is probably a lot faster than the heatsink thermal
time constant, but the average is still 60A, without looking at
switching loss.
the curves themselves have a Tc spec (80C & 110C) as well as Tj = 150C,
hence the 70K dT figure I used to work out the thermal impedance
required. The numbers just dont stack up. I'd believe that curve for
intermittent pulsed operation, but not continuous.
if its 120A at 150C Tj then fig. 6 gives Vce = 6V, for Pon = 720W, IOW
360W average. shove that down 0.5K/W and voila, 180K dT (assuming
perfect heatsink & thermal interface). then add in switching loss, which
is pretty large.
IMO anyone who looks at fig. 1 and thinks "wow, I can do 120A at 2kHz"
is in for an unpleasant surprise.
I prefer decent thermal models to Ztheta curves. kudos to infineon. some
of their spice models have a thermal feedback term too, making full
electro-thermal simulation straightforward in spice (assuming, as
always, that your [thermal] models are meaningful).
it should be trivial nowadays for manufacturers to develop highly
accurate thermal models - 3D FEA. After all, they know all the material
properties and dimensions. Hell, teledeltos paper would do the trick. Or
a fish tank and some perf sheet. Or a PhD and a month of algebra.
have you seen the 3-D SOA+lifetime curves in the siliconix mospower apps
book? lovely.
I have seen Semikrons mathcad models, which are exactly what you
describe - curve fits to measured data for device parameters, both
electrical and thermal. then a transient analysis that models the
thermal dynamics as well as the electrical ones.
Cheers
Terry
