high temperature hall sensor
Discussion in 'Sensors and Actuators' started by vamsee, Mar 1, 2013.
  1. vamsee
    vamsee
    36
    Jan 10, 2013
    Hi all!!
    I need hall sensor with 200°C operating temp. i cud find max of 150°C..
    will allegro, honeywell or anyother hall sensor producers customize it ?
    pls let me know
  2. (*steve*)
    25,497
    2,839
    Most semiconductors are rated only to 150C. Many are rated to lower temperatures. A few are rated to 175C. I've not seen any higher.
  3. vamsee
    vamsee
    36
    Jan 10, 2013
    thanx for the reply.. will they customize it to 200°C?
  4. vamsee
    vamsee
    36
    Jan 10, 2013
    i have mailed them, but still waiting for the reply..
  5. Harald Kapp
    11,660
    2,696
    They probably will not do it. Above 150°C semiconductor physics becomes tricky and 200°C operation may simply be not possible.
  6. vamsee
    vamsee
    36
    Jan 10, 2013
    Is that good idea to use heat insulator around 150°C hall sensor in the 200°C ambient temp?
  7. Harald Kapp
    11,660
    2,696
    Not if you can't actively cool the sensor to below 150 °C
    Maybe you can use a rod of magnetically soft material to sense the field and bring it to the sensor loacted in a cooler environment ? Probably not very practical, though.
