high temperature caps
Discussion in 'Troubleshooting and Repair' started by johnT, Oct 31, 2009.
  1. johnT
    johnT
    Oct 31, 2009
    can i replace a 105deg cap with an 85deg cap in my pc monitor?
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    Yes you sometimes can, but of course expect it to live a lot shorter than the original.
    The prob is that the 105deg one is probably a low-esr, while the 85deg ones are usually not, making them run even hotter than the original. You might also get undesirably high ripple voltages that might impair operation.
    If it's a small one (0.5-4.7uf) you migh want to opt for a plastic replacement which would give you the best performance and an infinite lifespan.
  3. jerryg50
    jerryg50
    57
    Apr 18, 2010
    High Temp Rated Cap vs Low Temp Rated Cap
    You can replace the cap with a lower temperature rated one, but its lifespan will most likely be reduced. It may be worth the extra effort to order a proper cap with the proper temperature rating. :)
    Jerry G.
