High temp thermometer.
S
Spehro Pefhany
Response time might be an issue. Smash the bulb.
Low wattage 120V bulbs are apparently mostly vacuum inside-- higher
wattage ones have some inert gas.
Why not use a thermocouple? Or an RTD? That temperature is in the
'friendly' range.
K
Ken S. Tucker
Jamie
Spehro said:
You can also make a Pirani vacuum gauge with one, if you can expose
the filament to the chamber.
if you're talking about an iron gauge, that requires a rather good
vacuums before you energize the heater. I suppose one could make one.
Mr Edison discovered the thermionic effect, trying to do research on
the soot build up on the heaters in lamps. His work led to many new
ideas that got stolen by big business and other proclaimed inventors.
Jamie
S
Spehro Pefhany
You mean an _ion_ gauge (eg. Bayard-Alpert)? No, those are kind of a
gassy triode.
A Pirani gauge measures the heat loss in keeping a filament at a fixed
temperature, which is more-or-less linear with pressure over a range.
Kind of like a hot-wire anemometer in still air.
Their useful range is mostly at higher pressures than the ion gauges
(before you dare fire up the filament in the ion gauge).
Jamie
Stolen _from_ Edison?
Best regards,
Spehro Pefhany
Jamie
gassy triode.
Yes, that is what I meant.
We also have a thermocouple vacuum probes in our system, too. It just
heats an element and senses it, but the ion gauge is the final
determination before HV is enabled.
Yes, that is correct. We have a separate control circuit just for that
area, which handles both aspects.
Sure.. Read your history.
http://www.andycowley.com/valves/old/history/genesis.html
You read down a bit and see how the Edison effect gets a
new label on it and then becomes some one else's property.
Nice world we live in. Bunch of cut throats.
Jamie
S
Syd Rumpo
On 28/05/2012 21:59, Bill Sloman wrote:
Choose your glass carefully. 2000F is 1093C, and soda glass melts
around there
http://en.wikipedia.org/wiki/Soda-lime_glass
Yes, use a halogen bulb - they have a quartz envelope which will easily
take that. A G4 capsule type isn't too big.
I used these as combined heaters/thermistors in a recent project where
the duty cycle was such that they had plenty of time to reach ambient
after the heating phase. Worked fine, but I found silver braze to be
the most reliable way of connecting wires which were then insulated with
fibreglass. In my case, the temperatures were lower than yours, so I
don't know if silver braze or fibreglass would survive.
Copper braid is tempting as connecting wire, but be wary of the odd
broken strand poking though the fibreglass sleeving, so use single core
if you can.
Cheers
U
Uwe Hercksen
LM said:
Today many bulbs or lamps are made of molybdenum. Because it is cheaper. So you should calibrate your sensor.
Hello,
the melting point of molybdenum is 2623 °C, but tungsten is 3422 °C.
Bye
K
Ken S. Tucker
Nice post Syd.
I'm planning to crimp steel or Cu wire to bulb leads.
For insulation, I figured on Telfon or ceramic, but fiberglass sounds
like a nice suggestion.
Lot's of good posts to this thread fellas,
Ken
S
Spehro Pefhany
A thermocouple starts to sound better and better. You can buy a cheap
DVM that has a thermocouple input.
OP: Send me your e-mail and I'll send you a type K bead thermocouple.
They're rugged, have fast response, are trouble-free and just what the
doctor ordered for this kind of application.
K
Ken S. Tucker
dynamics (at) uniserve.com
business address is
http://www.trak4.com/earco/index.html
OT:Just got a new organizer, so I have room for more good stuff,
http://www.flickr.com/photos/dynamics/?saved=1
In application, the 'thermometer/thermocouple' goes to a triac
controlled existing 'hot plate' heater.
Regards
Ken
K
Ken S. Tucker
Bill said:
As Phil Hobbs says, even at a sweet spot, they are still
thermocouples, and consequently unsuited to making accurate
temperature measurements, not that Ken S. Tucker is going to be
ambitious about accuracy.
Bill Sloman, Nijmegen
An "ambition" is to remove methanol from ethanol, but I think
a common diode series will do for that, otherwise quite true.
Ken
S
Spehro Pefhany
It's cheaper to buy pure ethanol in the first place.
Except for the taxes. According to C. this was a common activity among
the chemistry Uni students. Get it right and cheap booze, get it wrong
and you go blind!
Best regards,
Spehro Pefhany
S
Spehro Pefhany
Ken
BP of ethanol and methanol are 78.37°C/65°C so there's a reasonable
separation. AFAIUI, denaturing uses more than one additive so as to
make the process more difficult to reverse.
Best regards,
Spehro Pefhany
Jamie
John said:
Thermocouples are pretty good, usually better than their specs
suggest. They are much more rugged than RTDs, and work to much higher
temperatures.
The biggest practical problem is that most readout devices have
miserable cold-junction sensing for any CJ temperature but 20C. If you
do it right, it's remarkable how accurate thermocouples are.
Why do you reflexively add insults to most everything you post?
other issues with thermocouple process units is they need to operating
in the same ambient temperature as the device the probe is connected too.
The cold junction reference will miss calculate otherwise..The
seebeck effect is a basic thing, however, not very understood by a few,
especially those that carry a name of "SLow-Man"
Jamie
