High speed induction motor update
C
colin
If anyone remembers I was messing about trying to modify a 2 pole 240vac
induction motor to go at higher speed and lower voltage driven from a dspic
based 3ph pwm setup.
well I got some of that magnetic paper wich goes black in the presence of a
magnetic field,
I put a circle of it in the center of the stator but was very little to see,
it apears the paper only goes black if the megnetic field goes
perpendicularly through the paper,
wich it doesnt with it aranged this way.
but anyway I had a realy extra strong cup of coffee and traced how id
conected the 4 windings to the 3phase
(there were 16 slots wich made it awkward)
and realised id got one phase backwards.
changing that it now runs at a whoping 20krpm.
it realy starts to sing,
and its not realy balanced well enough as it only made for 1500rpm.
it was only an experiment,
I only put a few turns of wire loosly through the slots,
I also need to bore the rotor out so it can sit in the middle of a 1M long
12mm dia shaft.
I think I might need to trim the cooling vanes on the rotor too.
however I realy need a motor 2"x2" this one is a bit to big to fit in easily
at 70x70,
its from an old 8" floppy drive to drive the main spindle.
ive been looking around at all sorts of junk,
but nothing just the right size yet.
my usual stockists only seem to have larger motors.
Colin =^.^=
P
Paul E. Schoen
colin said:
dspic based 3ph pwm setup.
a magnetic field,
see,
long 12mm dia shaft.
easily at 70x70,
Colin =^.^=
You must be driving the motor with a much higher frequency than 50/60 Hz.
Probably more like 800 Hz. I'm surprised that an induction motor was used
in a floppy drive. It is more likely a synchronous motor. Even so, I wonder
about the 20krpm. You might not get very high torque at such high speeds,
and there may be heating problems due to magnetic losses. You may need
additional shaft support bearings if it extends so far from the motor
bearings. If the shaft end vibrates and goes off-center, at 20krpm it may
become a lethal weapon.
What is this gadget supposed to do?
Paul
John Larkin
magnetic field,
12mm dia shaft.
at 70x70,
Colin =^.^=
I suspect there's a fairly simple basket of wire one could shape that
both suspends and spins an aluminum sphere, driven by 2 or 3-phase
varoable-frequency AC. In a partial vacuum, such a gadget could rip
any rotor apart.
John
John Larkin
magnetic field,
12mm dia shaft.
at 70x70,
Colin =^.^=
Modern chem lab centrifuges and turbomolecular vacuum pumps use
magnetic suspension bearings and ac drive. They measure rotational
speeds in kilohertz.
John
C
colin
wonder about the 20krpm. You might not get very high torque at such high
speeds, and there may be heating problems due to magnetic losses. You may
need additional shaft support bearings if it extends so far from the motor
Ive wound it with 2 poles the same as it was before, so 20krpm =666hz.
I havnt checked it properly thats just going from the drive frequency.
if the motor slows down much the slip increases and it rapidly slows down
so its not far off 20k.
theres only 6 turns of wire on each segment to keep the inductance down so i
can drive it from 24v.
it struggled to get to 20k as my current limit kicked in before it reached
ful voltage
so i probably need a few more turns. but this was just an experiment.
I dont need torque, well no more than necessary to overcome bearing and wind
losses,
and im not realy sure how much that is.
although im puting less than 50w into the motor most of that is copper/iron
loss.
the bearings dont seem to get warm exept when I had to much preload.
the floppy drive was an old one, very old, sa801 8".
it does scare me a bit when it gets going, there are bearings at each end
however and the motor in the middle,
I also have 2 more bearings inbetween.
Colin =^.^=
C
colin
any rotor apart.
they have magnetically suspended high speed rotors in that gravity
experiment satelite,
but theyr driven by compressed gas.
im sure someone here could derive the failure speed of an aluminium rotor of
a given size.
they dont use titanium in jet engines for nothing, well they got hot as well
Colin =^.^=
C
colin
The electronics and software will go to over 100krpm,
its hard to get the moving parts, bearings etc,
to run smoothly enough even at 10krpm.
just getting the shaft straight is taking ages.
JosephKK
colin [email protected] posted to
sci.electronics.design:
=666hz. I havnt checked it properly thats just going from the
drive frequency. if the motor slows down much the slip increases
and it rapidly slows down so its not far off 20k.
down so i can drive it from 24v.
reached ful voltage
experiment.
bearing and wind losses,
copper/iron loss.
preload.
each end however and the motor in the middle,
Colin =^.^=
There are inexpensive motors and controllers that will do those
things readily available on the market. And they are less than 2
inches (50 mm) diameter and can deliver up to 400 watts (over 1/2
horsepower).
JosephKK
Hardly, dental drills and similar have done and do 100,000 rpm for
decades routinely.
C
colin
John Larkin said:
Air powered, air bearing PCB drills run up there, too.
yes but they dont have a 12mm dia 1M long shaft.
It probably wouldnt be so difficult if I had an engineering workshop instead
of an electronice workshop lol.
Colin =^.^=
John Larkin
Yikes! That will wobble itself to death at that speed. The fan shaft
on the JSF has similar issues; it transmits 32,000 hp to the forward
lift fan.
John
C
colin
lift fan.
well with bearings at 400mm intervals if its 10um out of tru in the middle
it does wobble a lot
at over a few k rpm
the catastrophic problem is at the point of resonance
wich is ~ 5krpm, it absorbs a lot of power too.
if I can get it to have no visible bend on my dial guage wich is probably
about 1um,
then it runs fairly smoothly,
however to straighten the last 10um is proving difficult,
I can bend it so its straight but an hour later it just goes back.
another bearing inbetween so theres 200mm between bearings is better and il
probably need it,
but the extra friction is a problem and even with these it still needs to be
straighter than it is.
Colin =^.^=
