[email protected]
I'd like to drive a ~400pF load ("electrode" below) at 1-10MHz,
100Vpkpk. I had a previous posting about this, and I got some
excellent advice about doing this with a RF amplifier (50 Ohm out,
which I have) + transformer (for voltage step-up) + resonator (for Z
matching to 50 Ohm):
.. ____________
.. G n1:n2 ,-----+------------+---+--)___________}---|
.. __|\__ T | | | | coax electrode (400pF)
.. | |/ | || # # _|_ | 1pF __
.. Vac # || # # L C --- '-||--)__ coax carries RF
.. |______| || # # | voltage-monitor
.. gapless | | Cdc | sig to cap. divider
.. pot core '--+--+---||--(#)--+-- gnd
.. | gapped current transformer
.. dc bias --\/\/--' pot core or small sense resistor
I'd like to know if it's possible to just drive this 400pF load with an
op-amp or common-emmitter amp. instead (so that I don't have to
impedence match). For example, I've seen the APEX amps, but those
can't quite reach 10MHz (good solution for 1 MHz though). I'd like to
be able to do the following:
__|\____ electrode (400pF to ground)
Vac
gnd
and be able to vary Vac from 1-10MHz with the amplifier putting out
100Vpp across the electrode. No coax necessary here. Am I dreaming
when I'm basically asking for a 10MHz 100Vpp op-amp?
.. ____________
Vac
gnd
