High speed binary counters
Discussion in 'General Electronics' started by David Moreno, Jun 11, 2004.
  1. David Moreno
    David Moreno Guest
    Hi !!!
    I'm in need of using a fast 8bit binary counter up to 100-150MHZ, I'm
    thinking on using a 74F269 or 74F779 but because I will using
    them on it's upper limits I don't know if it will work fine. Any
    suggestion ? (I'm also looking at a FPGA or PLD for doing
    the work).
    Thanks !
  2. At that frequencies the circuit design becomes important (stray
    capacitances, inductivities etc), so I'd go with an integrated
    solution and keep as much as possible of the high frequency stuff
    inside the chip.
    Does it have to be a synchronous counter? Are all outputs to be used
    or will it be used as a frequency divider?
  3. David Moreno
    David Moreno Guest
    Hi !
    Like a FPGA or so ?
    Syncronous counter, I'll be using all outputs to diferent circuits but
    it will work mostly like a frequency divider.
    Thanks!
