High speed ADC with USB interface
G
Guest
I'm looking for 12-16bit ADC with 4MHz samplingrate capable of storing 4K
samples, with USB interface to transfer data to a PC.
Any recommendation ?
U
Ulf Samuelsson
I doubt that you will find this ADC/USB/Storage on a single chip.
With 4 Mhz sample rate and 12 ´bit resolution
you need 48 MHz operation for a serial interface
so it is likely you need a parallell interface.
I assume you store the samples first and then send it over USB.
Then you need 8 kB of storage for the samples.
Is it acceptable to use a UART at 115 kbps which connects to a USB-Serial
bridge?
You can transfer 4kW in about 1 second?
You would be looking for a micro with
* DMA capability for 4 Mtransfer/s
* 16 bit Bus
* 8 kB extra SRAM (16 kB min)
* USB interface, or connection to an external UART-USB bridge
* External ADC
The AT94K05 FPSLIC has enough RAM and can directly interface to
the ADC using the FPGA area, but lacks the USB.
R
Richard Webb
Analog Devices do some evaluation boards for some of their ADCs which you
can interface to their 'USB FIFO' board, might be suitable, although I think
the ADCs in question are far faster than 4MSPS.
M
Mike
WoW now that would be something for sure - geeeesh as I ponder
the frailties of using a 60KVA 3-phase UPS as a paperweight !
G
Guest
My appologies.!.. Altough I said ADC, what actually I mean an ADC board, not
necessary single chip.
My corrected question is;
I'm looking for 12-16bit ADC Board with 4MHz sampling rate capable of
storing 4K samples, with USB interface to transfer data to a PC.
A
Antti Keskinen
not necessary single chip.
A 12-16 bit ADC with 4 Mhz sampling rate requires a minimum throughput of 48
Mb/s, and a maximum of 64 Mb/s. This means you must have a Hi-Speed USB 2.0
IC, which is capable of the theoretical maximum of 480 Mb/s.
One candidate is SMSC's GT3200. It has a 16-bit parallel interface, thus it
is possible to interface it with any modern microprocessor. For the ADC
unit, I'd look at Analog Device's ADC selection matrix. They have at least a
16-bit 65 MSPS (Million samples per second) device and a 16-bit 3 MSPS
device. If your sampling rate of 4 Mhz is absolute, the 65 MSPS is the
nearest suitable 16-bit one. The interface is parallel, thus it would be
directly compatible with the GT3200.
If a lower sampling accuracy is enough, AD also offers a 12-bit and 14-bit
10 MSPS devices, both with parallel interface. The upper 4(2) bits of the
USB unit could be used for signalling, if necessary.
I have only experience with the AD's ADC units, and they've been positive
experiences. Dunno about the GT3200, but you could try checking them out.
-Antti Keskinen
U
Ulf Samuelsson
If the board needs/has a sample buffer, then there is no need for the high
speed.
You get 4k samples and then upload it over 12 mbps USB at leasure.
/Ulf
