high-side mosfet scheme
Discussion in 'Electronic Design' started by Tolstoy, Aug 25, 2007.
  1. Tolstoy
    Tolstoy Guest
    I used to work on a bike with an old-fashioned generator that
    had a segmented commutator and put out dc. That means that a
    voltage regulator has to have a rectifier in it, to block
    the battery from discharging into the armature when you
    turn the bike off (they used a relay in the old days).
    I built a solid state regulator for the bike using a
    shottky rectifier, but now I'm thinking about ways to use
    a low-resistance mosfet in the high side so it doesn't
    require a heat sink. The suggested current limit for this
    generator is ten amps. A ten-mOhm mosfet would only make
    one watt of heat. The MBR3035PT shottky created five
    and a half watts at ten amps. So now I"m trying to figure
    out how to control a mosfet in the high side as
    a blocking diode and have it turn on and off, like a
    syncronous rectifier.
    The circuit will have a comparator that controls the
    field current, so I figured I might use a comparator for
    controlling the power mosfet as well. Since I'll have a
    charge pump for driving the mosfet gate, I can run the
    comparator off it. This means I can use an ordinary
    comparator to sense the voltage across the high-side mosfet.
    Here's an illustration of the basic topology I envision
    charge pump>---+-R1-+-||-+ |
    generator | | | |
    armature--+----|----|----' |
    R2 | '------, |
    | +-R4-, | |
    | \ | c |
    LM393| >---+-----b |
    | / e |
    | |/ | gnd |
    | gnd |
    '--------------R3----------+
    gnd
    The only problem is that the comparator may chatter
    at low charging currents. For example, if the comparator
    has an offset voltage of -5mV and the mosfet has 5mOhm
    Rds(on), then at currents less than an amp it will
    oscillate. I put the negative feedback capacitor there
    to alleviate it as much as possible. And though it's
    unlikely the generator will have to put out very low
    charging currents for any length of time,
    I still would like to find a way around the oscillation.
    Any suggestions?
  2. Why does it need to be such a sensitive switch? Couldn't you use an
    absolute reference for the turn-on, depending on the armature being
    well above some threshold while it's working?
  3. Tolstoy
    Tolstoy Guest
    It seems like they would have done it that way
    back in the day they used relays.
    They must have set the relay to engage at 15 volts or something
    on the armature and cut out at say 11.5, or whatever the armature
    would drag a fully charged battery down to, once the generator
    stops. I don't actually know how the
    cutoff relays in the old mechanical regualtors worked.
    Anyhow, taking that approach would call for a fixed voltge
    reference and a comparator with hysteresis.
    I'll have to think about it.
  4. ehsjr
    ehsjr Guest
    Yes - add a resistor for hysteresis. See
    http://www.maxim-ic.com/appnotes.cfm/an_pk/3616
    Ed
