Night Watcher
- Nov 6, 2017
- 7
- Joined
- Nov 6, 2017
- Messages
- 7
I bought an EMAX RS 2205 2600KV Motor, and I want to attach a slip ring to it that has 6 cables.
The slip ring will be turning at a minimum of 1440-1800 RPM, ideally it would be running at 3600 RPM, and at max it might be running at 72000 RPM. However depending on the price of such a slip ring I might settle for the minimum RPM.
The slip ring will be running for a few minutes on occasions, and therefor there's no need to look for something too durable, but I don't want something of terrible quality either.
I would appreciate your recommendation for a high speed slip ring that fits the criteria and can be installed on this motor, preferably from a company that ships worldwide.
Note that I never used a slip ring before, therefor I am unsure how to install one on this motor, and I would appreciate some pointers as well.
This is the motor I bought:
https://www.aliexpress.com/item/EMA...CW-Black-Prop-Nut-RS2205-for/32694139341.html
Thank you
Thank you
