High Q bandpass for 50kHz
Discussion in 'General Electronics Discussion' started by sbieker, May 3, 2012.
  1. sbieker
    sbieker
    May 3, 2012
    Hi everybody,
    I want to realize a bandpass for a center frequency of f0 = 50kHz with a Q factor of around 50 to 100, gain should be of order unity.
    I tried with an active bandpass with multiple feedback and also with a biquad active filter (each with OP37). In principle, both designs work but Q factors are worse than expedted. (I assume someone more experienced in electronics would easily figure out the reasons..)
    However, I found that National Semiconductor's AF150 seems to perfectly meet my demands. Does someone know if this circuit is still available or if there is any equal substitute? Where can I procure the device?
    Any hint is appreciated... thanks in advance!
    Steffen
  2. Wabajig
    Wabajig
    75
    Apr 14, 2012
    I remember in college we had a great result using same resistor and capacitor value in the feedback of an op amp circuit. It went resistor from output, capacitor to ground and resistor to the - input, all this in parallel with capacitor from output, resistor to ground, and then capacitor to - input. Maybe a 1k resistor for - input + input to ground, so it will invert the output. But very high Q. Can't remember the name of circuit. But it was based on the charging time constant of capacitors T=5RC math. Hope this help. John
  3. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    I have 'Electronic Filter Design Handbook' by A.B.Williams. He says that the multiple feedback circuit is suitable for Q<20.
    He gives an example of a dual amplifier feedback circuit with Q=70.
    He says the biquad can have Q=200, I do not know why your circuit does not behave, perhaps it is the frequency limitations of the amps.
  4. Wabajig
    Wabajig
    75
    Apr 14, 2012
    I remember there was a limitation on op amps of Hfe*frequency for each op amp. Hope it helps.
  5. Harald Kapp
    11,655
    2,696
    Another source of low Q may be tolerances of the components. Try to get components that at least match.
    Harald
  6. sbieker
    sbieker
    May 3, 2012
    Ok thanks a lot... I will try your circuit, Wabajig. Also I will try to take care that components match, maybe that improves the Q factor.
    Does anyone have an idea concerning the NS AF150?
