The circuit shown here ( ) is a high current voltage regulator. I built it to power six or more ultravoilet LEDs. The LEDs need 9 volts and about 1 amp each so they can operate.
I am using a computer power supply to provide 12 volts for the input of the circuit so I can get the 9 volt output. I am using only one transister at the moment which should allow the circuit to handle 8 Amps.
I was not able to get the 4.7K variable resister so I used the only one I could get which is a 5K.
When I hook up the circuit it was able to power a small fan but I could not reduce the voltage to the 9 volts I need.
Any suggestions on why this is happening ? . Thanks in advance for your help.
