A
aran
I will design an AC/DC power-supply that can give up to 100A with a voltage
range 2V-24V. Almost transient- and noise-free DC output is demanded. Would
like to switch between current-, voltage- or power (with maximum current
and/or voltage) regulation. I will also pulse the output, i.e. use the PS as
pulse generator (rectangular pulse shape).
I would like to hear opinion of the people out there for best design
principals.
I believe the switch-suppliers have higher noise than linear suppliers.
Using bipolar transistor(s) will give a low efficiency (as heat losses). May
be IGBT transistors used together with an integrated driver circuit?
I appreciate any suggestion, literature, link, etc.
principals.
