High current op-amp, small through-hole package
Discussion in 'Electronic Design' started by Marco Trapanese, Jul 20, 2008.
  1. Hello,
    I need an op-amp for a buffer application (in DC) with this features:
    * single supply: +5V
    * high output current: > 100 mA
    * package: through-hole, small as possible like TO220 or metallic case
    What would you recommend?
    Thanks!
    Marco / iw2nzm
  2. Mook Johnson ha scritto:
    Nope. I only have to buffer a Vref of a DAC (2V). So using an NPN after
    a buffer should do the trick if I have the space to place both op-amp
    and bjt.
    Thanks!
    Marco / iw2nzm
  3. MooseFET
    MooseFET Guest
    How about abusing a regulator like the LT3080. If the load is always
    sinking it works as a voltage follower with a low offset voltage.
  4. MooseFET ha scritto:
    It could be an idea. Thanks for the input
    Marco / iw2nzm
