hi fellow hobbyists.. ?about sensors
Discussion in 'Sensors and Actuators' started by elioacm, Dec 3, 2018.
  1. elioacm
    elioacm
    25
    Jul 7, 2013
    so i have been doing some researching about proximity sensors using IR reciever and emitter and going to buy the materials today.;
    do you guys can recommend me a thread here or a basic components materials needed
    for an example; lighting up an LED by which it will light when certain object has entered the proximity.
  2. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    Whilst doing this with discrete components is laudable I'd recommend you purchase a cheap'n'cheerful PIR sensor. These commonly use the BISS1000 chip and include all the parts you need at a price far below that of obtaining them individually.
    Google PIR Sensor Schematic on Google to see a gazillion schematics using such devices as the ubiquitous NE555 etc.
  3. elioacm
    elioacm
    25
    Jul 7, 2013
    but i want to make it from scratch, i just bought the materials needed yesterday and hope i can find out proper way to connect some of it on the board.. i have lm358 and some ir sensors i dont know if its correct for what am i trying to do.. its a blue and white one. i just gave the materials i need to the shop lady.
  4. Externet
    Externet
    733
    154
    Aug 24, 2009
    Obtaining the linked items, you can dismantle it to individual pieces, trace its schematic, learn/study how it works and put it all together again as you will have all the correct components, quantity-one and tested to work with no ordering wait, including the hardest to find, a proper housing, at an unbeatable price.
    Or, order the components found in it, and make another.
  5. CircuitMaster
    CircuitMaster
    48
    Dec 17, 2016
    hevans1944 likes this.
  6. elioacm
    elioacm
    25
    Jul 7, 2013
    ill get in touch been doing what all of you said.. ordered some parts online, but the materials that i have now arent working, got lm358 and copying the link you gave.. not working i have no idea if its the materials or something else my wiring etc.. and also planning on going to the hardware store to see and dismantle the parts that ill buy.
  7. CircuitMaster
    CircuitMaster
    48
    Dec 17, 2016
    Try measuring the voltage over the black diode, it should be "1.2-1.5VDC".
  8. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    ??? Doesn't make sense.
    this is something we cannot determine unless you show both the schematic you're building from AND the way you've done it.
    davenn likes this.
  9. BobK
    7,680
    1,685
    An infrared LED would have Vf in that general range.
  10. CircuitMaster
    CircuitMaster
    48
    Dec 17, 2016
    I don't know why my post was deleted, but I had this problem when I was building the same circuit recently, so I decided to ask.
  11. davenn
    davenn Moderator
    13,557
    1,854
    There is no post from you in this thread that has been deleted
  12. CircuitMaster
    CircuitMaster
    48
    Dec 17, 2016
    Thanks, I saw a notification that my post was deleted, maybe it was on another thread.
  13. elioacm
    elioacm
    25
    Jul 7, 2013
    ^hah... so me ill get in touch been busy assisting in a preschool event.. hope this thing my hobby project willl worrkk!! it would be great, im going to show the schematics and what after this event.. been delighted people replying thanks dudes aka fellow hobbyists teachers.. you make me so proud and making this my project a little bit brighter possiblIER is a big bonus! thx again.. ps: ill get in touch
  14. (*steve*)
    25,361
    2,756
    I deleted it and then restored it.
    davenn likes this.
  15. hevans1944
    hevans1944 Hop - AC8NS
    4,459
    2,074
    Jun 21, 2012
    After reviewing the OP's requirements for a proximity sensor, I would not recommend a PIR sensor for such an application. PIR sensors rely on the movement of objects with contrasting infrared emission, compared to the background infrared emission, and have zero range discrimination. PIR sensors will detect the movement of objects hotter or colder than the background infrared radiation at any distance within their field of view when the size and temperature of the objects provide enough contrast with the background radiation to present a usable signal.
    An active infrared emitter (IR LED) and a co-located infrared-responsive photo-diode, both devices pointing upward, appear to be the simplest way to create a proximity detector, responsive to a finger placed over (but not covering) the infrared emitter. A finger placed above the infrared emitter will reflect some of the infrared emitter radiation back toward the co-located photo-diode, which will then produce a signal that can be used to indicate proximity has occurred.
    Notice there are potential problems with this simple scheme. First, there is no way to distinguish infrared emission by the IR LED from other nearby infrared emitters. This can lead to "false positives" where these other infrared emitters indicate proximity is present when nothing desirable to detect is there. Second, sensitivity to variations in proximity detection range may cause unreliable operation or require frequent "tweaking" to establish operation. Still, this is an interesting project for beginners to try out. Infrared (or near infrared, which is what IR LEDs produce) radiation is a fascinating subject to explore, and the results (compared to visible radiation) are not always intuitive or even similar.
    One significant improvement that can be made in an infrared emitter and infrared photo-diode proximity detector is modulation of the infrared emitter with a square wave frequency of a few kilohertz. The signal from the photo-diode is then synchronously detected using the modulation frequency as a reference. The improvement in signal-to-noise ratio and detection sensitivity is enormous and usually well worth the extra effort.
    CircuitMaster likes this.
  16. elioacm
    elioacm
    25
    Jul 7, 2013
    got my lm358. going to buy soon new ir led and a photo diode (blue) these two should be bought from one source. going to try pir sensor and break them down as @kellys_eye said. ty for the replies. im making this project for 1year hope less than a year to master it
  17. elioacm
    elioacm
    25
    Jul 7, 2013
    hi guys im already got this one just now. dont have any research yet, on it how to use it.. but for now maybe you could help me? are you familiar with this? just got it working but i want to dismantle it but when i do i dont know where the pins should go.
  18. (*steve*)
    25,361
    2,756
    Vcc is your +ve supply, Gnd is -ve, and the out is the output
  19. elioacm
    elioacm
    25
    Jul 7, 2013
    yeah how about the circuit diagram
