HF Resonator
Discussion in 'Beginner Electronics' started by Boz, Oct 12, 2006.
  1. Boz
    Boz Guest
    Hello. I'm looking to make a 2" x 3 1/2" circuit that resonates between
    800Mhz, and 1Ghz. I use to use a chip a long time ago out of cheap hand
    held scanners, but they do frequency hopping which won't work for this
    application.
    I have to keep this simple because of the lack of board space, and I'm
    not using surface mount components.
    I was hoping someone here knew a good analog IC for this, so I can
    interface it with my pre-existing analog amp, and filter BUS's.
    Help and/or advice will be greatly appreciated!
  2. Boz
    Boz Guest
    Did I say something wrong?
  3. I'm not sure what you want.
    You seem to describe a filter or a tuned circuit and then say you want a
    chip to do it.
