C
Clive Mitchell
Hey kids... Let's take a laser to bits.
It doesn't seem that long since a club laser was typically an argon unit
with a water cooled head. Now with DPSS greens and surprisingly high
power "normal" red lasers the cost of a scanning club laser has crashed
to very affordable levels.
I just bought a three colour unit (red, yellow and green) on ebay with a
stepper based scanning system and really like it. Print out this
picture and I'll talk you through what's inside....
http://www.emanator.demon.co.uk/laser.jpg
OK. The green laser is the large black extruded aluminium chunk at the
front left. It's rated 50mW but because green lasers use a much higher
power infra red diode to stimulate a crystal to lase in a different
wavelength, then double it's output frequency with another crystal the
power dissipation tends to be pretty high compared to a conventional red
laser diode. Despite being half the optical power of the red laser the
green outshines it in perceived intensity due to the spectral response
of the human eye. It's very bright indeed.
The red laser is the surprisingly small brass tube clamped in an
aluminium bracket just to the back right of the green lasers black
extruded case. For 100mW it's tiny! But then the construction of a red
laser is very simple compared to other types.
The beams are combined by the 45 degree piece of dichroic glass mounted
on the short pillar in front of the red laser which passes the green
beam straight through but reflects the red beam sideways so that it is
in parallel with the green beam. The assembly is accurately positioned
so the two beams combine to produce a good bright yellow when both are
active.
The beams then pass on to the deflection system which is very simple in
that it uses two small stepper motors to wiggle two bits of front
mirrored glass. The stepper motors are high resolution, but the actual
movement is small so everything "drawn" by the laser has a slightly
stepped appearance with the mechanical mass of the rotors causing
"loopy" edges. At power-up the motors get their positional reference in
the same way as many moving mirror lights by winding round and stalling
against two protruding screws that have been "fine tuned" by being bent!
At the back of the unit is a transformer for the fan, steppers and
control card, while the lasers themselves are surprisingly controlled by
two independent mains powered switch mode supplies stacked on top of
each other. The switch mode supplies are at the middle left of the case
with the cream coloured PCBs. Each of the laser supplies has a simple
two wire logic level control from the main controller.
The main control PCB (the green one) has a bit of basic power supply
circuitry on it and a large processor which looks as though it might be
an Atmel, although there is a label covering the chip data. The
controller has 10 channel DMX and localised control options with a built
in microphone and sensitivity control. The stepper motors are
surprisingly controlled by a pair of ULN2803 octal Darlington arrays
with the circuits paired into four 1A drivers per chip. I suppose it's
an easy way of driving the steppers and has the nice benefit of
integrated diodes for shunting any inductive backlash from the windings.
And that's about it. The images projected onto a wall show the rough
output from the stepping motors, but when the beams are cutting through
the haze it looks great. The price difference between the stepper
version and the full galvanic (high resolution) deflection system is
huge so it's a small price to pay for a good visual effect.
In short quite a fun unit. Perfect for clubs or just as a techno-toy.
The unit dissected in today's class was the EL-150RGY bought from:-
http://stores.ebay.com/Laserworld-Shop
Right. What can I take to bits next.
active.
